I've had a DUHA and the Ford under seat storage in my f150 and Raptor screws, and my old f250 screw had the factory under seat storage. I've never had any storage in a SCAB. I've been looking for something for my 2013 SCAB and there seem to be several options; DUHA, Husky, off brand... Anyone have any experience with the SCAB versions of any of these? Don't really need the locking type, but I'd consider one if the cost is reasonable or the product is really that good. Pics would be great, too. Thanks
I had a DUHA in my 2003 supercab and I really liked it. The installation was quite simple and it held an enormous amount of stuff. The dividers/gun holders were pretty useful to create separate compartments in the DUHA, but were also easily removed to allow for storage of longer items. Unfortunately I don't have any pictures.
I should add that I was not overly impressed with the DUHA fastening system. The Ford unit mounted with bolts and existing holes. Seemed more thought through when engineered.
I'm not sure about the Crew Cab version of the DUHA, but the Supercab version that I had was mounted to the floor with one bolt on each side. The passenger side used the bolt that normally holds down the spare tire tools, which I then relocated above/behind the DUHA on the passenger side, and the driver side uses an existing Torx head bolt that is bolted into the cab already. It was a pretty secure mounting and I never had any trouble with it moving after the installation. I am not sure that Ford ever had a factory storage bin for the Supercab configuration.
sounds much better than what I had... Mine had a couple straps that wrapped around the seat base.
