Sponsored by: Real Truck
Severely confused
Old Feb 23, 2019 | 11:43 PM
Severely confused's Avatar
Severely confused
Severely confused
I have changed 5 EGR coolers and 5 oil coolers so I deleted my EGR cooler by placing freeze plugs in each end and welded it shut during the process I must have hit one of the injector connection so I replaced the injector put it all back together won't start if I keep cranking till my nerves give out it'll start trying to hit then the IPR fault code pops up that's when my nerves give out it ran fine when I pulled it in the shop just blowing a little white smoke now it'll crank but no start almost like no fuel checked that no problems could it be a bad connection not having a good connection with the ficm or fuel lines full of air. It's a 2005 6.0
Edit
Old Feb 25, 2019 | 07:26 PM
Fefanatic's Avatar
Fefanatic
Did you mig weld those with the engine wiring harness still connected? If so it's possible (more like probable) you fried the ficm. You will need to go back to basics and start checking voltages. It would also help to have a scanner so you can answer questions that probably will be coming your way.
Old Mar 3, 2019 | 03:10 PM
Severely confused
EGR cooler
I welded it out of the truck then put it back in then hooked everything back and then hooked up the ficm last then hooked up the batteries
Old Mar 3, 2019 | 03:13 PM
Severely confused
EGR cooler
Also checked the ficm and was getting 45v so all was good there
Old Mar 3, 2019 | 05:00 PM
bayou barataria's Avatar
bayou barataria
You may have turbo problems blocking the egr, tried that on my old 6.0 ( probably unrelated to your current problem) When I blocked mine it burnt through the metal eventually
Old Mar 3, 2019 | 05:02 PM
bayou barataria
P.S. when my 6.0 acted like yours now it was the hpop seal, common problem with those.
Old Mar 3, 2019 | 05:15 PM
Severely confused
EGR cooler
I thinking that I'm just gonna go back to running the EGR cooler that's seems to simplest way to fix my problem
Old Mar 3, 2019 | 05:17 PM
Severely confused
EGR cooler
Thanks for the info
Severely confused
Feb 24, 2019 07:59 PM
Severely confused
Feb 24, 2019 10:57 AM
Severely confused
Feb 24, 2019 12:36 AM
karter81
Apr 7, 2015 01:17 AM
Jpereira4065
Jan 28, 2013 10:06 PM
