Egr delete- HELP-No start
Hey everyone I am in serious need of help, I did an EGR delete from sinster diesel and now truck wont start
trouble codes :
U0105 P0118 P0198 U0306 P0472 P0670 P0683 P2285 P0046
Truck cranks but doesnt turn over, there is fuel at the injectors, no smoke coming from the tail pipe, FICM is reading 48v
trouble codes :
trouble codes :
trouble codes :
Since you have a Wide Varity of DTC AND MOST I looked UP were because OPEN CIRCUIT do this Below
Well Start Tripple Checking all the Wire Harness Plugs make shure they All Seated Good and fulley together
Best thing is to deleate and plug egr valve back in with the Valve still the its Bore
As you can see now the PCM gets Pissed when stuff is unplugged
with the deleate the egr valve does nothing except keep pcm Happey
plus it looks more stock
Okay awesome will do thanks for the help! I'll post again tomorrow and let you know how it goes
Martyn Allison
6.4L Power Stroke Diesel
01-25-2016 08:49 AM
MarkCol
1999 to 2016 Super Duty
11-01-2015 08:14 PM
