A big Question
Old Feb 23, 2019 | 07:51 PM
Megathomas's Avatar
Megathomas
Exclamation A big Question
can a 1995 ford E4OD 4x4 be converted to 4x2, I know the extension housing is different but not the gasket to it. Is it possible and is the shaft long enough?
Old Feb 23, 2019 | 08:40 PM
Conanski's Avatar
Conanski
Yes it is possible but the trans must be completely dismantled to change the output shaft.
Old Feb 23, 2019 | 09:44 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
The better question to ask is; Can a 4wd E4OD be used in a 2wd truck?
Yes,with a transfer case.You wont have 4wd of course without a front axle but you'll be able to make use of a 4wd trans and have a set of low range gears to use.You'll need the driveshaft from the same 4wd and wheelbased truck or have yours shortened.
You can always bolt in a front axle and drive shaft down the road or even at the same time and have a full 4wd convert too for that matter if your 4wd E4OD parts truck still haves them and the price for a package deal is good.
..........Oh you have an F350.I was thinking F150 for some reason.The full 4wd convert isn't that easy like the F150 but the 4wd trans and t-case info still applies.
Old Feb 24, 2019 | 10:53 AM
'89F2urd's Avatar
'89F2urd
To his point above, I actually like a transfer case in 2wd applications for the low range...mainly for backing up heavy trailers.
jaimalade
Aug 28, 2022 08:27 AM
timmyboy76
13
Dec 18, 2017 11:43 PM
Glockem45
May 14, 2009 08:43 AM
Pickupmanx2
May 12, 2009 11:59 PM
hush210
May 25, 2007 12:00 AM
