NP435 2wd/4wd
Old May 12, 2009 | 09:46 AM
Pickupmanx2's Avatar
Pickupmanx2
NP435 2wd/4wd
Quick question, will an NP435 out of a 70 4wd work in my 66 2wd? I know it's not alot to work off of, but I am going down to Fresno today after work and was going to look at one.
Thanks
Joe
Old May 12, 2009 | 11:59 PM
85e150's Avatar
85e150
If the 4wd trans has diff tail shaft housing to bolt to transfer case, it will need to be changed. Which will probably require complete disassembly of the trans. Best wait for a 2x model.
If it's a divorced TC, then you might be in luck. A quick look will tell the tale.
stuart olson
May 30, 2017 11:58 AM
towmaster
Mar 9, 2016 01:41 PM
351coupe
Feb 4, 2014 09:57 PM
Scifi266
Sep 22, 2010 08:57 PM
Slow
Nov 19, 2007 11:27 PM
