Sponsored by: Real Truck
Rear block swap
Old Feb 19, 2019 | 07:59 AM
rickkk's Avatar
rickkk
Rear block swap
Hi all, I have a 2004 f-350 LWB Crew cab Lariat. I swapped out the rear 4" blocks for 2" ones I now have take off shutter & vibration around 45 mph. Have had the u joints replaced twice and shafts balanced to no avail. Been told to shorten up the carrier bearing bracket or to maybe use one from a 2010 f-250. Does anyone have any thoughts on which way to go? Thanks in advance.
Old Feb 19, 2019 | 08:03 AM
Sir Kayakalot's Avatar
Sir Kayakalot
Were the blocks you removed tapered? Did you replace with a flat block? You might have changed your pinion angle. Would definitely cause vibration
Old Feb 19, 2019 | 09:05 AM
Mike189677's Avatar
Mike189677
if anything it would be the other way around the blocks for the 2 piece driveshaft trucks are flat from the factory, but you may be on to something here.
96sherm
Jan 31, 2013 07:10 AM
sandman3510
Jan 24, 2012 12:17 PM
breezy5000
Nov 26, 2011 06:31 PM
smoky_diesel
Oct 12, 2007 02:58 PM
krewat
Apr 1, 2006 06:29 PM
