Wobbly Harmonic Balancer
Old Feb 17, 2019 | 10:33 PM
coltonoslund's Avatar
coltonoslund
The new one is on its way. Just thought y'all would like to see how bad it can get.
Old Feb 18, 2019 | 11:44 PM
mark a.'s Avatar
mark a.
Hell I had one fly right off.
Old Feb 19, 2019 | 07:13 AM
Tedster9's Avatar
Tedster9
Cool video! The Y block in my slick had exactly the same when I got it twenty years ago. A good highway run would cause it to go catawampus (precise technical term) like that.
The inertia weight is designed to absorb crankshaft torsional vibrations. Due to the pulse of the pistons, the loading and unloading etc, the crankshaft under certain conditions can actually twist back and forth up to 2°, the idea is that the heavy steel weight itself sandwiched in elastomeric (rubber) to the damper hub, leads and lags a bit.
When the rubber turns to stone though there's no longer any spring action, and it simply breaks the bond and does whatever it wants. The crankshaft has at least a couple specific RPMs in the band where it will reach resonance and at least one of them is somewhere in there where we drive. It's enough in extreme cases to cause cracks or even break crankshafts. I'd expect more commonly it contributes to rear main seal leaks and beats the hell out of thrust bearings, main bearings, &c.
crazy96863
Apr 12, 2013 01:39 PM
F-250 restorer
Jun 18, 2012 10:04 PM
wmason
Sep 24, 2005 03:27 PM
texlex
Sep 23, 2002 06:21 PM
beau2
Jan 5, 2002 11:18 AM
