Changing balance weight
Old Apr 12, 2013 | 10:32 AM
crazy96863's Avatar
crazy96863
Wondering if something will work... I have a 50oz roller block assembly I am assembling to replace a 28oz assembly... The 50oz will require a flywheel and a damper I do not yet have. I do have the 28oz flywheel, crank, and damper.
After thinking about this for a bit, I cant see any reason why simply installing the 28oz components into the roller block wont work. The boat I am doing all this to ran well for years under the 28oz crank so if smoothness or whatever is an issue, its a negligible difference.
I can and will do the 50oz crank if its absolutely needed but otherwise would like to save a couple hundred bucks on parts I dont need.
The 28oz crank has seen less use than the 50oz but both are serviceable. Plz advise. Thx.
Old Apr 12, 2013 | 12:52 PM
xlt4wd90's Avatar
xlt4wd90
The complete 28 oz crank parts should work together. You may run into a problem with the newer block. After late 1982, the blocks used a 1-piece rear main seal, while the blocks (and cranks) before then used the 2-piece rear mail seal, but the change from 28 oz to 50 oz imbalance occurred in 1981. So it's very likely that your crank needs a 2 piece seal, while your block uses a 1-piece seal.
Old Apr 12, 2013 | 01:39 PM
crazy96863's Avatar
crazy96863
Yeah... I was just thinking about that... I think I am already committed to the 50oz.
luckydoggy
Jan 13, 2009 05:59 PM
70blue
Apr 27, 2007 07:53 PM
Handegard
Aug 13, 2006 10:46 AM
the breeze
Jul 12, 2005 07:37 AM
f100guy
Oct 7, 2004 12:35 PM
