1978 - 1996 Big Bronco
Need 78 rear window help
Old Feb 17, 2019 | 05:58 PM
sudsmcduff's Avatar
sudsmcduff
Rear power window help needed. Getting constant 12v from Blk/wht wire all the way back to key switch with key off. Safety switch tested good. Window motor works fine off of 12v. Key switch gives motor 12v in both directions. But motor won’t turn off of key switch unless I ground one of the motor wires. Is this a bad key switch symptom? Thanks.
Old Feb 18, 2019 | 10:29 PM
Bruners4's Avatar
Bruners4
Not sure if all of this applies to your Gen 2 or not.
1983 Ford Bronco Tailgate Tech pictures, videos, and sounds | SuperMotors.net
Old Apr 19, 2019 | 08:36 PM
yzfanimal's Avatar
yzfanimal
Did you resolve this issue?
Old Apr 19, 2019 | 08:39 PM
sudsmcduff's Avatar
sudsmcduff
it was the motor. All though it bench tested good in both directions. Replaced it and all good now
Old Apr 19, 2019 | 09:02 PM
yzfanimal's Avatar
yzfanimal
I had a similar problem with my 79, but the gear in the window motor had split in 3 pieces...
2.7EcoBoost
2015 - 2020 F150
Aug 5, 2019 11:12 AM
pappy19
Jan 31, 2016 07:37 PM
axbrya
17
Dec 23, 2011 09:40 PM
krantzfamily
Oct 31, 2004 08:12 PM
Mac55
Oct 3, 2002 05:02 PM
