Transfer case motor
Old 02-16-2019, 06:23 PM
Byf's Avatar
Byf
Byf is offline
Transfer case motor
2011 F150 FX4 ecoboost. When I try to shift into or out of 4WD I get check 4X4 on the display. I have to turn the switch multiple times before the transfer takes place. When it does happen it usually goes to 4L, no matter if I'm trying to go into or out of 4WD. Before I buy a new transfer case motor is there anything else I should do. Im not a mechanic, but do some work on my vehicles. Any help would be appreciated.
Old 02-16-2019, 10:28 PM
steve(ill)'s Avatar
steve(ill)
steve(ill) is offline
you could pull the motor off the case, set it on a block and operate it in the open to WATCH what happens.
Old 02-17-2019, 12:00 AM
Byf's Avatar
Byf
Byf is offline
I thought about doing that but didnt know if there was enough wire or if fluid would leak
Old 02-18-2019, 05:13 PM
CathedralCub's Avatar
CathedralCub
CathedralCub is offline
Any bad noises coming from it when this is happening? You can get a better ear on it by trying it with the engine off and ignition on.
Old 02-18-2019, 05:14 PM
CathedralCub
I agree with steve(ill), just keep in mind that it might appear to operate normally without any strain and still operate incorrectly when installed and it actually has things to push around in there.
97blaq4x4
07-29-2010 06:15 AM
nab101eg
2004 - 2008 F150
05-26-2010 03:19 PM
Awesome Bronco
1978 - 1996 Big Bronco
07-30-2004 10:03 AM
Quick Reply: Transfer case motor
