Currently in the garage and need help with OEM Led headlights
The retrofit source.com has the kit headlights for $2000. Harness kit is $300
LEDEVERYTHING coupon code is 10% (-$230 off)
so for $2070 for the package it’s not bad.
Fogs are an extra $175
how much is the stuff for Ford Scan ?
Amd side note. I purchased the 6 bulb kit from headlight revolution. Supernova V3. With in 11 months, one fog and one headlight bulb failed. I called and got replacements but customer service wasn’t the best. They sent me Version 4’s. Suppose to be better and brighter. Not At all. Also the Fogs has the wrong size bezel and they had to send more replacements that were “filed down”. Also there not extending my 2 year warranty. I went with the so called Highend bulb, figuring I would put them in once and not have to worry about them for years.
I don’t have to much faith in the new bulbs. After spending about $500 and a few hours installing the both sets. (12 bulbs) . I wish I would have done an OEM LED conversation
I have having to do **** over.
I also did Rigid industry’s D2 Pros for my fogs with KD Fabworks mount.
Alittle update,I called Retrofit solutions and asked tech support about the problems I’m having.They said I was the third person who called about the high low problem.They already have come up with a solution as there is a isolated issue with some of the new harness’s.He said he would ship it out ASAP,So sounds like that problem is solved.
They didn’t have any idea about my [ ] not going to full power.I told them about Forscan and he told me there is no need to do that that the harness solves everything,Should work factory right out the gate.
I have contacted three people that have done the conversion all the way down to XL trucks and all have worked flawlessly.Im still going to look into Forscan like you guys suggested.
A few years back, they had harness problems with 2015-2017 F150 owners attempting the same OEM LED headlight swap.
**Update** Well after taking the whole front of my truck off again to see if I could figure out why my [ ] wouldn't go to full bright when put it in drive,Long story short It was my ground....It wasnt a good enough ground for the headlights to work properly where I had It.Fixed that and everything works as it should now besides the bright lights.Morimoto still has to send out the adapter for them to work.
Thanks again for the help.
