Currently in the garage and need help with OEM Led headlights - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > 2017+ Super Duty
Reload this Page >
2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
Old 02-16-2019, 05:38 PM
nico963's Avatar
nico963
nico963 is offline
nico963 has a great reputation on FTE.nico963 has a great reputation on FTE.nico963 has a great reputation on FTE.nico963 has a great reputation on FTE.nico963 has a great reputation on FTE.
Iím currently installing OEM LED headlights on my 17 lariat with factory halogen lights.I bought the morimoto harness and have installed the new led headlights.Im finding that it seems the DRLís donít seem very bright and also when I put on the bright lights the top light goes out...They both donít stay on?
Any help would be appreciated as I have the whole front of my truck apart right now.
Thanks
Old 02-16-2019, 05:56 PM
RONMCHUGH's Avatar
RONMCHUGH
RONMCHUGH is offline
RONMCHUGH is starting off with a positive reputation.
Can't help with the headlights , but it seems like I saw a post in the forscan thread about someone figuring out how to increase the brightness of the drl's .
Old 02-16-2019, 06:06 PM
nico963's Avatar
nico963
nico963 is offline
Ok thanks,Iím on morimotos site now and watching YouTube videos to see If I can narrow it down.
Old 02-16-2019, 06:17 PM
nico963's Avatar
nico963
nico963 is offline
I just donít understand why Morimotosís installation instructions show five connectors and my harness only has four connectors?
Old 02-16-2019, 06:21 PM
mhoefer's Avatar
mhoefer
mhoefer is offline
mhoefer has a great reputation on FTE.mhoefer has a great reputation on FTE.mhoefer has a great reputation on FTE.mhoefer has a great reputation on FTE.
The [ ] lights are the only one that runs as a DRL on the stock lights, though with Forscan yes, you can make them brighter, and other parts of the light can be made to be the DRL as well.
Old 02-16-2019, 07:07 PM
nico963's Avatar
nico963
nico963 is offline
Ok so I understand,Because my truck doesnít come with factory DRLís I have to use forscan to make them come on and bright?Cause right now the only way the [ ] are coming on is if I put on the parking lights and headlights.If no parking lights the lights donít come on at all.
Im also gonna assume that forscan is the only way to make both lights come on when using the brights?
Old 02-16-2019, 07:29 PM
Mack3006
Mack3006 is offline
Mack3006 is starting off with a positive reputation.
How is the quality of that wire harness? Itís $400, just wondering the quality and if itís really plug-n-play
Old 02-16-2019, 07:44 PM
nico963's Avatar
nico963
nico963 is offline
It looks nice to me.I found a discount code through Facebook and ended up only paying $70 for the harness in the end of the entire purchase including the headlights.
Honesty Iím disappointed right now because I thought ďPlug and PlayĒ was just that.It seems now Iíve got to get into Forscan and that was what I was trying to avoid as Iím alittle afraid of it.
As I sit here I really hope Forscan will make them bright and DRL cause Iíll be real pissed if I canít make the truck work as factory.
Old 02-17-2019, 06:19 AM
Poncho450's Avatar
Poncho450
Poncho450 is offline
Poncho450 is gaining momentum as a positive member of FTE.Poncho450 is gaining momentum as a positive member of FTE.
I also had to go to Settings/Advanced/Lighting on the truck to select "Daytime Lights" as well as making the FORScan adjustment.
Old 02-17-2019, 11:55 AM
mhoefer's Avatar
mhoefer
mhoefer is offline
Yes, Forscan is the answer. Because it’s an American truck, yes you may well also need to select DRL in the settings like Pncho mentions. Then you’ll want Forscan to enable Bambi mode as well, leaves driving lights on when on low and high beam. You will also have to change a few lines code to enable low and high beams to be lit up at the same time. The Forscan thread will have all the codes you need and I can pull what mine are to get them.
Old 02-17-2019, 01:58 PM
JustMe1616
JustMe1616 is offline
JustMe1616 is starting off with a positive reputation.
Where did you order you Headlights from? I'm interested in doing this swap also.
Old 02-17-2019, 06:26 PM
nico963's Avatar
nico963
nico963 is offline
Originally Posted by mhoefer View Post
Yes, Forscan is the answer. Because itís an American truck, yes you may well also need to select DRL in the settings like Pncho mentions. Then youíll want Forscan to enable Bambi mode as well, leaves driving lights on when on low and high beam. You will also have to change a few lines code to enable low and high beams to be lit up at the same time. The Forscan thread will have all the codes you need and I can pull what mine are to get them.
man that would be great,Any help would be much appreciated!
Old 02-17-2019, 06:30 PM
nico963's Avatar
nico963
nico963 is offline
https://www.theretrofitsource.com/
I used the code,LEDEVERYTHING and got a big discount.You could try it,I donít know if it will still work or not.I bought them about 2 months ago and just got around to installing them.
Old 02-17-2019, 06:37 PM
mhoefer's Avatar
mhoefer
mhoefer is offline
Nico, I will have to wait to get the computer from work and hook it up.
Old 02-17-2019, 09:06 PM
JustMe1616
Thanks, I hope it all works out for ya. If you don't mind, post some pictures when your done. Would love to see it. Once again, thanks.
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
