Sponsored by: Auxito
Powersteering pump or ????
Old Feb 16, 2019 | 10:09 AM
npccpartsman's Avatar
npccpartsman
02 F150 w/ 4.2 2wd.
All of a sudden, sitting still, the truck won't turn but LOTS of hollering from the pump, which is pumping because I can see fluid flow in the reservoir. Get it moving just a bit and it steers fine. No noise until you get the wheels turned fully right or left then it growls, but not as much as when trying to turn sitting still. What's going on? Pump or steering box? Fluid isn't dark and doesn't smell burnt and no air bubbles.
Old Feb 16, 2019 | 04:58 PM
CathedralCub's Avatar
CathedralCub
FTE Community Team
The pump is probably getting tired.
Try this: put the transmission in Park with the parking brake OFF.
At idle, you still have this problem, right?
Run the engine up to 1,000RPM, does the problem go away or get better?
If not, run the engine up to 1,500RPM, does the problem go away or get better?
Guessing it has by now. If so, it's probably a tired power steering pump.
Old Feb 17, 2019 | 02:59 PM
npccpartsman
For whatever reason, the center sheared out of the pulley, but the pump isn't locked up and still turns freely. With 216K on it I just replaced them both with an Advance reman (only because I had to get it back on the road). It didn't even break or burn the belt, but it did get to sit in a BAD part of Little Rock overnight and it's back on the road this morning.
I don't disagree that the pump was probably getting tired as it was factory.
Old Feb 19, 2019 | 01:21 PM
CathedralCub
FTE Community Team
Wow, that's weird. Thanks for letting us know how it came out!
Opossum
Jun 26, 2010 12:41 PM
FESTER1st
May 20, 2008 01:43 PM
TommiFIN
Mar 10, 2007 07:53 PM
lakerats
Oct 26, 2006 09:32 PM
Vampiro
Jun 21, 2002 12:25 AM
