testing TPS voltage / help
Old Feb 15, 2019 | 08:57 PM
Will Joyce's Avatar
Will Joyce
supposed to get no more than 1 volt when probing the green wire on tps with KOEO- Get 0 volts no matter what wire I probe -- should be getting good connection --removed the insulation on the new TPS & put probe right on the metal whwere the wire goes in . Did I buy a faulty tps --Still trying to figure out the irratic high idle problem .Any help appreciated. I did put it on by not knowing you supposed to set them (or clock them).
Old Feb 15, 2019 | 11:28 PM
vjsimone's Avatar
vjsimone
What is the Year & Engine ?
Old Feb 16, 2019 | 09:17 AM
Will Joyce's Avatar
Will Joyce
Its a 87 f150 302 --p o said an early to mid 90,s engine had been put in --Was unsure --makes me wonder if it was done at all --would like to find out what year it is but I dont know where to look --Do you?
killergsxr1
16
Dec 16, 2024 10:44 PM
Mark Twain
21
Sep 21, 2022 10:36 AM
Tom D
Aug 3, 2018 06:57 PM
Evill Ed
Sep 26, 2004 09:28 PM
Redneckerson
Jul 8, 2002 08:59 PM
