Brake Pads
Old Feb 15, 2019 | 01:16 PM
Richwon4's Avatar
Richwon4
Brake Pads
Lots of brake pads out there....my Ex has 100k on it. I want to drive it 100 more. What do you recommend front and rear? Thanks
Old Feb 15, 2019 | 01:18 PM
unleashd's Avatar
unleashd
I've been running Wagner Brake pads for a couple of months now, probably ~3K miles. So far, they have performed very well. The EX stops when I want it to
Old Feb 15, 2019 | 07:11 PM
ToolmakerRob's Avatar
ToolmakerRob
I have used a variety of different pads over the years but some of mine have wore out prematurely due to the slider pins seizing up. For the fronts I know some people have had great luck with EBC pads.
Rob
Old Feb 16, 2019 | 08:02 AM
pirate4x4_camo's Avatar
pirate4x4_camo
hawk LTS is my prefefence
https://www.hawkperformance.com/lts
ordered through autozone and they have a lifetime replacment warranty.
Old Feb 16, 2019 | 08:14 AM
carbon coupe's Avatar
carbon coupe
Yup, I've been running Wagner on everything I own for years. Very low dust and great stopping power, even when hot.
Old Feb 17, 2019 | 08:40 PM
DSMMH's Avatar
DSMMH
I agree with pirate4x4. For brake performance, wear and low dust Hawk LTS is the best for the X. Will be a little pricey and well worth the extra $.
Ed
Old Feb 20, 2019 | 10:54 PM
jgoldsmje's Avatar
jgoldsmje
Power stops
I went with power stop set up...slotted rotors, calipers and pads set up.
Old Feb 21, 2019 | 10:48 AM
ShelbyHauler's Avatar
ShelbyHauler
Rob
My 69 Mustang was hardly stopping with my new slotted rotors and semi-metallic pads from SSBC. I put a set of EBC Yellow Stuff on the front and now it stops. Hawkperformance might be as good, but I only wanted to do this once and get it right. Not that I'd use the Yellow on my EX, but they do seem to bite much better on my Stang.
Old Feb 21, 2019 | 02:17 PM
andym's Avatar
andym
If you use EBC Yellow stuff pads on your Excursion, they will stop great, create TONS of dust, and chew through your rotors. Ask me how I know.
I now use Hawk LTS pads and cryo rotors. Looks like you can get two rotors and a set of pads from Amazon for about $395.
Amazon Amazon
Amazon Amazon
Amazon Amazon
Old Feb 21, 2019 | 02:53 PM
BatteriesNotIncluded's Avatar
I've been looking at Hawk LTS pads and Cryo rotors too (Frozen Rotors, to be specific)
Does anyone have any advice on good calipers for all round?
Old Feb 21, 2019 | 02:59 PM
andym's Avatar
andym
I would go Motorcraft on calipers. That's what I just put on. They're supposed to be pretty good and my set of Napa premium calipers lasted three years before they froze up.
While you're at it, you may as well add a set of Russell stainless steel brake lines. They much improved pedal feel on my Excursion - of course, this was over the original, 18 year-old hoses.
Here's the link for the set that fix the Excursion:
Amazon Amazon
Old Feb 21, 2019 | 03:08 PM
WE3ZS's Avatar
WE3ZS
And don't forget to do a full complete brake fluid flush, getting all of the old, dirty and wet fluid out will make the entire system feel much better.
Old Feb 21, 2019 | 04:39 PM
WE3ZS;18496796]And don't forget to do a full complete brake fluid flush, getting all of the old, dirty and wet fluid out will make the entire system feel much better.
Had that done just two weeks ago when my rear brake line failed me.
Frozen Rotors are quoting me on a full set of their calipers (they only have fronts listed on their website). They are expensive, but they are not rebuilds and I figure if I'm putting in their pricey rotors, I may as well go all out.
Old Feb 21, 2019 | 06:17 PM
pirate4x4_camo
as far as I know rayspestos is the only company making new calipers and as of now they only make the rears, About $75 on rockauto
Old Feb 22, 2019 | 11:45 AM
DavenTn's Avatar
DavenTn
One of the easiest jobs to do is, rebuilding your original calipers.
Matthewyfz
May 10, 2019 08:53 AM
pkenn7
Oct 28, 2010 10:12 PM
fuelman
Jul 23, 2010 10:50 PM
Silverrv
Dec 27, 2003 07:10 AM
