Rear bottom door latch
Old Feb 21, 2019 | 09:05 PM
BigVic1972's Avatar
BigVic1972
Looking for the rear door latch that goes on the bottom driver side rear door.
Old Feb 22, 2019 | 07:32 AM
WE3ZS's Avatar
WE3ZS
Welcome to the EX forum!
Is your latch broken, missing or just inoperative?
Old Feb 22, 2019 | 10:18 AM
seville009's Avatar
seville009
Old Feb 22, 2019 | 02:01 PM
ShawnQ's Avatar
ShawnQ
If you're talking about the barn door on the driver's side rear, and you are replacing because it isn't working, then you probably just need a cable. Or, better yet, just cable ends.
I found a 'how to' on here, but ended up saving myself some time.
1) Drilled out 2 pop-rivets on the barn door handle (1/4" bit)
2) removed latch mechanism via 3ea T-27 Torx bolts located on underside of door
3) removed entire assembly through the hole where the 'handle' goes.
- Once it was out, found broken plastic on both ends of the cable. Removed remnants of plastic, and installed these on each end:
https://www.amazon.com/iFJF-Expedition-Excursion-Navigator-Aluminum/dp/B075CY27Q9/ref=sr_1_2?s=automotive&rps=1&ie=UTF8&qid=1550865509&sr=1-2&keywords=ford+door+latch+repair+cable&refinements=p_85%3A2470955011 https://www.amazon.com/iFJF-Expedition-Excursion-Navigator-Aluminum/dp/B075CY27Q9/ref=sr_1_2?s=automotive&rps=1&ie=UTF8&qid=1550865509&sr=1-2&keywords=ford+door+latch+repair+cable&refinements=p_85%3A2470955011
4) cable ends may require some 'cleaning' to remove burred plastic, and make them smooth. A little bit of sandpaper or a file will make it quick. Once the plastic sheathing is smooth, slide the cable sheathing into the new metal cable ends, with cable running through the slot.
****If you can't get the cable or the sheath to fit, spread the metal ends apart with a wide flathead screwdriver or chisel until it all fits. Once it all fits, you can clamp it back tight with pliers.
5) reinstall cable into latch mechanism
6) reinstall cable into handle mechanism
7) reinstall latch into door via 3ea T-27 torx bolts
8) reinstall handle into door with 2ea 1/4" rivets.
Took me less than 15min. The biggest thing is I didn't have to deal with removing the interior door panel and plastic weather shield. Some people would rather do that than mess with rivets. I have rivets and a rivet gun handy, much easier.
daiges
1997 - 2003 F150
Jan 31, 2019 02:02 PM
perzaklie
17
Sep 10, 2017 03:03 PM
Spaznaut
Oct 13, 2014 06:09 AM
John in Vegas
Sep 26, 2013 02:32 PM
a1tech
Jun 8, 2008 11:26 PM
