Bent Push Rods
Old Feb 14, 2019 | 02:42 PM
chasteen1156's Avatar
chasteen1156
Bent Push Rods
I have a 1999 F250 7.3 Powerstroke. It is bending intake pushrods on 3 cylinders. I have removed the heads and checked for stuck valves or bent valves. Nothing wrong there. My thought is that the valve lifters must be sticking and causing the pushrods to bend. All the rest of the valve train is in good shape. Am I going down the right path and is there some way to test the lifters? I don't think you are supposed to be able to push them down if they are working correctly but how do you test if they are stuck at the top of their travel? The engine is out of the truck at the moment.
Old Feb 14, 2019 | 07:10 PM
z31freakify's Avatar
z31freakify
What about if its not the lifters and its actually hydrolocking? Lifters going bad on these engines is rare. When my engine took a dump @ 800k + i still had the stock lifters.
Old Feb 15, 2019 | 07:18 AM
chasteen1156
Would the injector seals possibly cause it to hydrolock? I had not thought of that being a possibility.Thanks for the idea.
Kyle Wood
18
Mar 22, 2018 06:40 PM
406angler
Jul 23, 2017 08:38 PM
Romel77
Mar 1, 2016 06:20 PM
79Ford250MR
Feb 19, 2014 10:13 PM
Ben_E
Oct 15, 2002 04:33 PM
