Battery light woes
I went to start it Friday evening, and no dice. Not enough juice in the batteries. I suppose the batteries are ready for replacement, but I have a feeling there’s an underlying issue that I’m not finding.
Any suggestions from the gurus?
A voltage reading on the batteries and at the dash might show something. Check it engine on and off. Keep in mind when starting cold the glow plugs will be on for a while, and that will suck down the voltage almost a full volt until they turn off.
A new alternator cannot charge depleted batteries. Especially a new single 110 amp alternator that only puts out 50 amps at idle.
I did charge both batteries when the new alternator went in. I knew to do that right.
Denny
Did an alternator test too, and it passed just fine, but my battery light still remains on. I came to the conclusion that my battery issue was just that, a bad battery. My battery light is another issue, and most likely it’s grounding out somewhere. A weekend project to ensue...
Denny
Denny
For a 2000 7.3L, the PCM is out of the picture in terms of the battery indicator light being on or off. The instrument cluster is in the picture, which is where the 470 ohm resistor is located. See green box in photo below:
It is rare, if not unheard of, for there to be a problem with this resistor.
I think the OP is on the right track looking at wiring. First wire to look into is that Light Green wire with the Red stripe, Circuit 904, aka the "I" circuit. If it is on when the engine is running, that suggests the wire could be shorted to ground, which is exactly what the OP already plans to investigate.
With the key in the ignition set to Run, and the engine off, the indicator light should be ON, and there should be between 1 to 3 volts measured between that LG/R wire at the alternator harness (harness side, not alternator side) and ground.
If instead you are finding zero voltage, there is an open in that wire.
If you are finding 12+ volts (or whatever volts your batteries are currently putting out) then take away the meter, plug the harness back into the alternator, and start the truck, turn on the headlights, and run the blower motor up to high. If you have a high idle tune, then set that up, or have someone step on the accelerator pedal to bring the engine to 2000 rpm steady state and hold it there, which will bring the alternator to 6,000 rpm full tilt maximum electrical output. The headlights and blower motor fan on High are necessary to create a load to induce the alternator to put out the current to satisfy the load, for purposes of the next test, which is the difference in voltage between the batteries and the alternator at full tilt.
Now, with all that blaring away, go back under the hood and measure the voltage drop between the Black with Orange Stripe B+ alternator output terminal, and the positive battery post. This can be done by attaching the negative lead of the meter to the alternator B+ terminal, and the positive lead of the meter to the positive battery terminal.
If the voltage drop is less than 0.5 volts, the problem is inside the alternator.
If the voltage drop is greater than 0.5 volts, then there might be some corrosion in that Black with Orange Stripe wire, or maybe one of the two fusible links is fried.
Now, going back to the Light Green/Red wire... what if the battery indicator light is OFF when the key is on, and the engine is OFF? Try grounding the LG/R wire between the harness at the alternator and ground. Now did the light go on? Then that would be another indication to change the alternator. Or, you can try changing the voltage regulator instead, because the fault is more likely in the small circuit board of the voltage regulator.
For additional information see Diagnostic PinPoint Tests J and L, Charging System, Section 414-00-28, Ford Workshop Manual, F-Series SuperDuty
Sounds pretty straight forward to me. Then we can get out the tasers, lazers and Phazers,
Denny
