Engine shudder
Old Feb 13, 2019 | 11:09 PM
Brannon Sanford's Avatar
Brannon Sanford
Engine shudder
Got a 95 5.8 when the engine warms up and I accelerate the truck wants to shake/shudder when i hit the gas a bit to get up to speed it will go away, after it shifts it will continue to do it but not as much I've been told it can be miss fire and I've changed everything and seems like it's still doing it did research and found out it could be the pick up coil or the torque converter wich means i could have more than one problem what should I do just have a diagnosis done so i know before I start throwing money at it?
Old Feb 14, 2019 | 07:48 AM
rla2005's Avatar
rla2005
Try sticking to one thread for the same issue: https://www.ford-trucks.com/forums/1...esitation.html
All you had to do was reply back stating you still have the problem after replacing the parts mentioned.
mandy2013!
2009 - 2014 F150
28
Mar 28, 2021 12:45 AM
jettrobombino
2004 - 2008 F150
Nov 20, 2010 01:24 AM
DAVID'S97F250HD
Mar 16, 2007 12:20 PM
aurgathor
Mar 17, 2006 03:03 PM
Perfect Details
1997 - 2003 F150
Nov 18, 2004 02:05 PM
