2013 ford f150 ecoboost torque converter issues - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2009 - 2014 F150
Reload this Page >
2009 - 2014 F150 Discuss the 2009, 2010, 2011, 2012, 2013 and 2014 Ford F150 Advertisement
Old 11-08-2018, 03:08 PM
mandy2013!
mandy2013! is offline
mandy2013! is starting off with a positive reputation.
I'm just a girl, don't really know much but need confirmation I'm being told right...
My baby is a 2013 FX2 ecoboost 160,000 miles. At highway speed 70-80 if I go to accelerate (too hard too quickly I guess) my truck begins to shudder, loses power & the yellow check engine light flashes for about a minute then all goes back to normal. Sometimes when the flashing light stops it will stay off other times it will stay on & that's annoying because then my remote start wont work till my husbands friend comes over with some computer thing & clears the code.
THEN other times when I'm just rolling slowly through a parking lot my truck will make the violent hard jerk 1 time then its fine. it literally feels like I just got rear-ended.
is this in-fact my torque converter yall think or...???
One sec., small history note: When this happened before FORD Dealer said it was a misfire of cylinder 3 & they "fixed it".
Um, no, NOT FIXED.
Ok any advise welcomed.
Thanks,
Old 11-08-2018, 09:37 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Mark Kovalsky is online now
Mark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputation
It certainly isn't the torque converter. The ONLY way the check engine light can flash is for an engine misfire. You have a misfire problem.
Old 11-08-2018, 09:52 PM
ford390gashog's Avatar
ford390gashog
ford390gashog is online now
ford390gashog is a splendid one to beholdford390gashog is a splendid one to beholdford390gashog is a splendid one to beholdford390gashog is a splendid one to beholdford390gashog is a splendid one to beholdford390gashog is a splendid one to beholdford390gashog is a splendid one to beholdford390gashog is a splendid one to behold
You need to service the plugs and coils, also consider drilling a hole in the intercooler to drain the moisture. The 6r80 is a good transmission, when was it last serviced?
Old 11-08-2018, 10:22 PM
mandy2013!
Meaning the spark plugs? My husband replaced them all and the problem continued. Sorry, you have to really break this down for me lol.
Thanks, Mandy
Old 11-08-2018, 10:27 PM
mandy2013!
Hi, my husband did replace all the spark plugs but the problem continued. That was after Ford said the fixed the cylinder 3 that was missfireing.
Not that my truck has warranty anymore but... Will making the hole you suggested make it to where the dealer wonít be willing to work on it in the future. I know probably a really really stupid question but lol had to ask.
Thanks, Mandy
Old 11-09-2018, 12:49 AM
ford390gashog
Has your truck ever had the misfire TSB done? It involves the shield on the intercooler. Some of us drill a small drain hole in the intercooler, especially in high humidity environments. It helps the condensation drain.
Old 11-09-2018, 06:22 AM
tseekins's Avatar
tseekins
tseekins is offline
tseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputation
On the ecoboost, you have to replace the boots and the plugs at the same time of the misfire problem could persist intermittently.
The hole that was referred to in the intercooler is a 1/16th size hole on the drivers side lower corner of the intercooler. The hole isn't large enough to lose any boost but just large enough to force out all moisture that otherwise may be getting drawn into the intake system. I did it about 40,000 miles ago and nary an issue.
Lastly, as asked before, when was the transmission serviced last? At 160K, you're due for a flush as per your owners guide.
Old 11-09-2018, 08:06 PM
mandy2013!
Hi, Iím so sorry I realized I didnít hit that question after I had already replied.
No the transmission hasnít been serviced so Iím sadly overdue.
Been holding out due to the expense of it & thinking Iím going to have the cost of the torque converter too.
As for the spark plugs, wires & boots I would hope that my husband did all three things!?!? The boots I assume are the black L shaped looking things right?
I definitely plan to ask him about making the hole. Heís a diesel guy & heís done this that & the other to his turbos & DPF or something like that. Now itís my trucks turn for some TLC.
I appreciate all the info! Thanks a bunch!!!
Old 11-09-2018, 08:25 PM
70f100longbed's Avatar
70f100longbed
70f100longbed is offline
70f100longbed has a great reputation on FTE.70f100longbed has a great reputation on FTE.70f100longbed has a great reputation on FTE.70f100longbed has a great reputation on FTE.
Definitely need to do the coil boots at the same time as the plugs. The drain hole is a good idea too. You need to get it scanned again to see which cylinder is now causing the misfire and put another plug in that one. I normally replace the coil as well for good measure. What happens with worn plugs is the spark jumps between the plug and boot instead of the electrode. When that happens a small amount of rubber is vaporized and leaves a carbon track in the boot and on the plug. Now the spark has 2 routes to take instead of 1. When you just replace the plugs the track is still in the boot so the next time the spark jumps outside it makes a track on the new plug. Then if you just replace the boots or the coil thinking the plug is new so it has to be good the track remains on the plug. Have to do them as a set.
Old 11-09-2018, 10:44 PM
Mark Kovalsky
Replacing the torque converter will just waste a lot of money. There is nothing wrong with the torque converter.
The problem is in the engine, not the transmission or torque converter. Listen to what the others are telling you about the spark plugs/boots/coils. That's where the problem lies.
Old 11-09-2018, 11:00 PM
mandy2013!
Thank you so much to all you guys! Sorry Iíve been kinda weird or whatever on the messages. This is my 1st time on this site and trying to learn how to navigate it without ignoring anyone & on my cell has been a little trying.
Iíll definitely push my husband to revisit everything you guys advised on and put the torque converter out of his mind. Our neighbor says his truck had the exact same issue on his Expo as Iím having and the resolution was the TC so....
Thanks again!!!!
Old 11-10-2018, 10:56 AM
brokenleg
brokenleg is offline
brokenleg has a good reputation on FTE.brokenleg has a good reputation on FTE.brokenleg has a good reputation on FTE.
99% of the time its the engine causing the shuddering and vibration. The torque converter almost never gives problems.
Old 11-10-2018, 06:06 PM
ford390gashog
Also worth mentioning but when it misfires and the light is flashing you are causing damage to the catalytic converters and it's not cheap to replace them.
Old Yesterday, 04:16 PM
mandy2013!
Thank you! I think Iíve finally convinced my husband through all the info the others have provided me to look back into their suggestions rather than proceeding with the TC. Iím terrified now that the CAT will be trash due to how long weíve put this off.
I appreciate everything from everyone!!!!
Old Today, 05:43 AM
Lectrocuted
Lectrocuted is offline
Lectrocuted is starting off with a positive reputation.
Cats may be fine. Solve the misfire with above advice and go from there.
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
