Speedometer Needle Bouncing?
Old Mar 2, 2019 | 07:41 AM
GLR's Avatar
GLR
Originally Posted by pchelp
The same thing is happening in my 69, Has anyone had any issue with the speedometer eating up the speedometer cables? I every time I pull it out it looks like a mouse nest just behind the dash. I have replaced it twice in two years.
Is there a kit to adapt it to an electronic system?
What shape is the housing in? Is it resting on an exhaust pipe? Is there a sharp bend in the housing? A measurement from the chewed up cable part will give you an idea of where to look.
Old Mar 2, 2019 | 10:03 PM
pchelp's Avatar
pchelp
Originally Posted by GaryKip
As it has been said before, "Google is your friend" Check out this link:/www.hotrod.com/articles/electric-speedometer-conversion-junkyard-builder/ If not, you could buy and install a cheap GPS. That would show precise speed.
Very interesting article, wish they had used a Ford for the story.
Old Mar 2, 2019 | 10:06 PM
pchelp's Avatar
pchelp
I’ll let you know when I put the new cable in, last time I replaced it I really didn't give the speedometer much thought.
Old Mar 4, 2019 | 07:29 PM
alaricsept's Avatar
alaricsept
while we're on cable cleanup. Im back on the site with another engine swap question, I am resto-moding a 65 f100, I put in a 351w (from 79), and a c6 (from 77) I am having the tranny worked on now bcs it skips 2nd gear on shifts, (it pulls like a diesel in 3rd though), anyhow... I am having trouble getting my speedo gearing worked out, if I run the calculation it says I need a 12 tooth gear??? lowest I can find is a 16 tooth gear. 3.00 Rear (probably 3.08) normal C6 gearing and 30" tires. Is my calculation right. Speedo is way off. The stock 3 speed was very similar in gearing to the c6, so I thought I wouldn't have to change it but it is way off, am I barking up the wrong tree?
Thanks Big Al
Old Mar 4, 2019 | 07:45 PM
GLR's Avatar
GLR
Ford Speedometer Gear Calculator
According to this you have to know the # of teeth on the drive gear in the trans . On the C6 I don't think you can change it.
You might have to get into the speedometer head
Old Mar 7, 2019 | 01:17 PM
alaricsept's Avatar
alaricsept
yea, I talked to summit and some other places and they said it should have 6 teeth in the transmission. I think I have it figured out at 18.5 teeth which would either be and 18 or 19 tooth so I bought both and will try them out. It's still in shop for tranny repairs... going on 9 days...
Old Mar 9, 2019 | 05:38 PM
pchelp's Avatar
pchelp
Here is what the core looked like after 1,000 miles. I put another new cable on the speedometer and took some videos.
Old Mar 9, 2019 | 05:47 PM
GLR's Avatar
GLR
That cable was seized somewhere. Enough lube on the new one? Sure there is no sharp bend in the housing?
Old Mar 9, 2019 | 08:19 PM
pchelp's Avatar
pchelp
Yep, the cable was still wet with oil. I made sure to have as few bends as possible, could this have happened from over tightening?
mzavenm
Jun 19, 2018 07:19 PM
sigtauenus
Feb 15, 2007 02:22 PM
RDON
N. California Chapter
Mar 1, 2005 06:41 PM
tasdad
Feb 12, 2004 01:53 PM
XLT79Ranger
Aug 13, 2002 10:15 PM
