72 sport custom
Old Feb 9, 2019 | 10:47 PM
my72's Avatar
my72
72 sport custom
Hi, I just got a 72 f100 sport custom with a 390. Problem is its been hit in the front, took out the whole front clip,fenders, inner wheel wells, radiator support, radiator and front bumper. Hood might be able to be reworked not sure. My question is are f250's of the same year compatible? They seem to be more plentiful around here.
Old Feb 9, 2019 | 11:02 PM
hivoltj's Avatar
hivoltj
Yup, all the light duty f-series the same.
Old Feb 9, 2019 | 11:11 PM
my72's Avatar
my72
It has 5 lug wheels, are those 5x5 or 5x5.5?
Old Feb 10, 2019 | 06:59 AM
lilorbie's Avatar
lilorbie
they should be 5 on 5 1/2. if it,s a stock truck.
Old Feb 10, 2019 | 08:20 AM
my72's Avatar
my72
Thank you for the info. I found a donor truck for $350, going to get it today if everything goes right. Then if I have frame problems I have a.new frame for it. As they say free isn't free. I got the truck from a friend who's kid wrecked it.They just wanted it gone. Everything that needs to be done I'll do myself, I usually do my own paint and body work so that's a money saver. I don't like electrical but as long as your grounds are good then its just patience. I'll get some pictures on here so you guys can see what I'm dealing with. You might see something that I don't. Thanks again for the help so far.
Old Feb 10, 2019 | 09:57 AM
lambchops25's Avatar
lambchops25
Hey my72, I left you a visitor message on your personal page.
Old Feb 10, 2019 | 10:29 AM
hivoltj's Avatar
hivoltj
Sorry no, the suspension/brakes/hubs will he a little different on a 3/4 or 1 ton. I thought you were talking sheet metal parts only
Old Feb 10, 2019 | 12:03 PM
my72's Avatar
my72
Hivoltj, yes I was talking about sheet metal, so its all good thank you
Old Feb 10, 2019 | 02:13 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Not quite.
1967/72 F100/350: There are TWO different radiator supports. The support used with the Super Cooling radiator has a larger opening radius.
If the support is for a Super Cooler, and your truck doesn't have it, the mounting holes won't line up, so you'll have to fab up some brackets.
If your truck has a Super Cooler, and the radiator support isn't for it, you'll need a sawsall to trim the support, then drill new mounting holes.
1970/72 grille frames: 1970 is 1970 only. 1971/72 is the same, but the 1971 plastic grille inserts look slightly different than 1972.
Brakes: 1968/72 F100's have 11" x 3" front drum brakes. 1967/72 F250's have either 12 1/8" x 2" or 12" x 2 1/2" front/rear drum brakes.
1968/72 F250 2WD's were available with optional dual piston caliper disc brakes. The rear drum brakes are 12" x 2 1/2."
F250's have 8 lug 16" wheels on a 6.50" bolt circle, so F250 brakes and related parts will not fit F100's that have 5 lug wheels on a 5.50" bolt circle.
Old Feb 10, 2019 | 08:55 PM
my72's Avatar
my72
Thanks for the great information. I just picked up a 72 for parts with a standard shift, the fixer upper is an automatic.
Old Feb 10, 2019 | 09:21 PM
lambchops25
Cool. Hopefully you can get that truck on the road soon.
dthut
Jun 6, 2017 12:22 AM
airharley
16
Jun 4, 2012 01:08 AM
vinlin95
Dec 21, 2007 01:56 PM
dsmm6
Nov 6, 2003 12:50 AM
flyboy2610
Paint & Bodywork
Jan 2, 2002 08:47 PM
