radiator questions
Old Jun 1, 2017 | 06:49 PM
dthut's Avatar
dthut
radiator questions
hey guys, my rad is shot and i have a few questions.
79 f250 with a 390fe
Im trying to avoid spending 600.00 on a new supercooling rad that came stock with my engine.
Can i run the smaller lighter duty rad in my truck?, Im not doing any towing its just my daily. (that rad is 200.00)
Or does anyone know of a cheaper rad from a different year or model that matches up?
Old Jun 1, 2017 | 06:53 PM
Tedster9's Avatar
Tedster9
Sure it can't be repaired? Sometimes they can, sometimes they can't.
Old Jun 1, 2017 | 07:00 PM
ktm4012's Avatar
ktm4012
I just ordered this one from Rock auto for $119. Hopefully it works ok.
http://www.rockauto.com/en/moreinfo....sn=437&jsn=437
Old Jun 1, 2017 | 07:06 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
4 different radiators were available for 1973/79 F100/350's.
The standard, xtra cooling and A/C radiators measure approx: 26 1/4" wide x 19 1/4" high. The only real difference is the thickness of the cores.
Super Cooling radiator has a HUGE top tank, it's wider and deeper than the other radiators. Measures approx: 26 1/4" wide x 24 1/4" high.
1973/78's with round headlights have two different radiator supports. One was only used with the Super Cooling radiator, as it has a larger opening radius.
D3TZ-8005-G .. Super Cooling Radiator 2 5/8" thick core / Obsolete = 1973/76 F100/350 360/390; 1973/77 F100/350 460.
Old Jun 1, 2017 | 07:35 PM
Blue and White's Avatar
Blue and White
It sounds like you have an older engine (390) in a later truck... pretty common. can you post a pic of your current radiator? It may help with responses.
In general, a cost effective 3 core Champion would probably provide the cooling you need if it bolts up. If it does not fit or if there are gaps around the radiator that let air bypass, it may not work so well. That is why the pic would help... to see what you are starting with.
Old Jun 1, 2017 | 08:51 PM
PapaBearYuma's Avatar
PapaBearYuma
When the supercooling radiator in my 77/460/C6 could no longer be repaired, I bought the cheap one from AutoZone. I think it's two row.
I expected the worst, but it's towed the boat to the lake in the summertime with no problems. Drove all day through Mexicali traffic at 100 degrees and never got over 210
I was concerned, but the cheap two-row has been fine.
Old Jun 2, 2017 | 04:04 AM
mark a.'s Avatar
mark a.
I can say this for sure, my stock rad for the 400 I used to run would not cool my 460. Everybody said it would but it didn't. Went with this 4 row Super cooler and it has never got hot since. It is big and heavy and a 2 person job to put it in without damaging it. Back in 2007 I got one from Performance radiator for $360. Guy at the rad shop said it was a import. They were somewhat light on the solder holding the tanks together, hasn't leaked since resoldering the tanks though.
Old Jun 2, 2017 | 03:59 PM
D-rat's Avatar
D-rat
the factory 3 row crapped out on my truck a while back. Replaced it with a $275 Autozone 2 row aluminum unit and it cools much better, even in 100 degree heat with the AC running.
I was skeptical at first, but I'm a believer now.
Old Jun 2, 2017 | 07:26 PM
kegger66's Avatar
kegger66
I put a "plastic top" cheapo in my dent a couple years ago and it's worked like a champ ($200 I think). Truck stays between 180-190 at all times (A/C, texas summer, etc.)
Old Jun 2, 2017 | 11:26 PM
F-250 WARHORSE's Avatar
F-250 WARHORSE
I have the 4 row supper cooling radiator, was able to cool a 545 stroker, a 460 built up, and a 400 either driving around, towing, offroading, or whatever. I know I willspend the extra for a super cooler if need be again. My local guy can recore those for less than new .
Old Jun 3, 2017 | 04:01 AM
burnthelight88's Avatar
burnthelight88
I just did the champion 3 row about 6 months ago. Got it off ebay which saved me about $50 compared to the champion website. Its aluminum, lifetime warranty (used it once already for a defect from the factory), and about the same money as the autozone ones that don't have a lifetime warranty. I highly recommend it.
Old Jun 6, 2017 | 12:22 AM
bryanmartin's Avatar
bryanmartin
Modine part number 545. The thing is huge, but is a drop-in replacement. It's been keeping my built 473 in my '79 Bronco cool for almost 12 years.
shark25
Nov 24, 2017 11:38 AM
Number4
Apr 21, 2017 10:21 AM
dipstick429
Jan 13, 2017 02:40 PM
Dace
Jun 10, 2016 06:30 PM
1976 Highboy Ranger
Sep 28, 2014 08:01 PM
