Electrical???
Old Feb 9, 2019 | 10:35 PM
eagle275's Avatar
eagle275
Electrical???
Thursday afternoon, got on I-40 West-bound, 96 F-350 4X4 460/C6 was running great, getting up to road speed, I know fuel pumps are good, both tanks full, and it started sputtering hammered down sputtered and cut off, got it over to the right shoulder so roll-back could get to it., Wouldn't crank, motor was turning also, thought it would fire up tried both tanks, and no go. Called AAA put it on roll back. Any thoughts? Could it be ignition module? Thanks guys!
Old Feb 10, 2019 | 07:26 AM
Mo8414's Avatar
Mo8414
Hard to say what it is untill you do some basic checks to make sure its a spark issue or a fuel issue.
Old Feb 10, 2019 | 09:13 AM
subford's Avatar
subford
What was turning the engine if it "Wouldn't crank"???
Cranking is the turning of the engine with the starter.
Are you saying it will crank but not start?
If so then on a 1996 the Black ICM is more than likely OK. They very seldom go bad.
Maybe you lost the PIP. Check it with an LED test light on the top wire of the ICM as it is cranked.
Old Feb 10, 2019 | 11:36 AM
Tedster9's Avatar
Tedster9
I understand a little bit of Southern, allow me to translate.
If a good ole boy sez "Hey Y'all, it got so damn cold last night my truck won't crank!" that does mean it won't start, though the engine will turn over (crank). Hope this helps. I make awesome sausage gravy and scratch biscuits too, so trust me, I know what I'm talkin' about.
bcompton35603
Sep 25, 2015 10:36 AM
ktenney82
1997 - 2003 F150
Dec 1, 2013 09:37 PM
02GrayPowerStroke
Dec 30, 2009 10:26 AM
jackone
Sep 20, 2005 08:25 PM
hoggylee
1978 - 1996 Big Bronco
Feb 2, 2001 09:23 PM
