Reverse and no 4x4?
Old Feb 9, 2019 | 10:13 PM
jdw1's Avatar
jdw1
Reverse and no 4x4?
So wondering why I have 4x4 in forward and when I put the truck in reverse it seems to disengage the 4x4?
2000 Ex in sig
thanks in advance?
Old Feb 10, 2019 | 12:19 AM
Tuquala's Avatar
Tuquala
Only thought I have is that maybe your Ex has had the oem vacuum hubs replaced with aftermarket ones. Had a Scout with Warn "auto" hubs that would engage (via roller clutch internally) when 4 wheel was engaged. Only worked going forward, and the clutch would unlock in reverse. They had a manual position which locked the hub so it worked both ways, but had to be unlocked when not using 4WD. Don't know if they are still made and available. Was early days stuff, so you could engage 4WD if needed quickly without leaving vehicle to lock hubs in.
Old Feb 10, 2019 | 09:06 PM
Peace2Peep's Avatar
Peace2Peep
Our trucks only have 4x4 in forward modes unless you lock in the hubs manually. When locked in, they work in both directions.
Old Feb 10, 2019 | 09:41 PM
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
No, if you have a correctly working ESOF system it works in any direction, any speed. Ran mine for years during the winter in the auto setting never lost 4x4 in reverse.
Sounds like a bad hub to me?
reamer
2004 - 2008 F150
Mar 19, 2011 06:08 AM
Sonic Blue
Jan 4, 2009 08:53 AM
inline6 Red Neck
Feb 14, 2007 01:01 PM
Bill Hanson
1983 - 2012 Ranger & B-Series
May 11, 2005 07:25 PM
drfbuster
Dec 25, 2004 02:06 AM
