Buying A 6.0 With Blown Head Gaskets?
Check out Anthony Youngblood’s Youtube video where he unboxes new Ford 6.0 heads and they are warped out of spec right out of the box. Guess what? Ford doesn’t believe in milling heads for flatness so they’ll throw warped heads on a block and torque down some head studs and they’ll still probably have blown head gaskets in no time. Not no but HELL NO!
I’m sure some guys on here will attest, I have no personal experience with them but I do own a 6.0 that needs new heads. Probably cracked and warped so I’ll be doing good to get UCF to give me my $250 each core return when I buy my o-ringed heads from them next week.
I agree, Ford owns the re-builds.
Those are not warped out of spec. They are cupped, but my swag is that is the natural stress of the casting. My one head shows signs it was previously machined but mapping of the surface shows it has the same profile of the other CBN machined head from the factory. So there's a good chance is that where they move to. Do we really think the particular head in that video was machined that way as a new part? It's more likely it stress moved that way afterwards. Clamping over the thinker rings of the gaskets around the cylinders doesn't help and can promote the issue as well.
The Ford engineers I worked with were sharp and would research parts to no end. With in their own department of get Ford's Scientific Research Group to do so. Considering they changed the spec from what the motor manufacturer stated in it's manuals for head flatness tells me they most likely investigated what was happening more then International ever did on their own.
Mark, I'm not sure Ford owns the rebuilds entirely. CAT did the diesels, my reman tag shows International, and Ford may be getting the part then through International. But I have no problem hitting on Ford for not going after the issue. It's sold to their customers, the dealer and then to the Dealers customer, in this case me.
I realize it is complicated though .................
I'm not really challenging one thought or another. I know for us as an example on the Superduty 99-04, we were the supplier of the brake pads to Akebono, Akebono the supplier of the pads and caliper to Ford. But if any problems with pads, it was Ford in our plants. Same for the following years when TRW supplied the calipers. Not first tier. But first tier with the Motorcraft parts. Who's on first.
Warranty cost get eaten by the base supplier, if it was a pad issue, the total burden was on us. The reman situation is a god only knows situation on how the contracts were written. My approach in the video will be it's on Ford.
Went to the store and got Afrin for tomorrow am to see how my voice will be so I can close this up.. The afternoon will be like having a spike in the middle of my forehead.
http://www.powerstrokediesel.com/doc...d%20Engine.pdf
This is the route I’ll go if I need a long block. Very impressive reviews and some personal friends have a few products and are happy.
https://killdevildiesel.com/collecti...oke-long-block
#28
#29
#30
I'm sure KDD makes a quality reman, but I don't have $6200 in the budget for a new long block. At this point, my options are essentially to buy the truck and take my chances with the heads/block being salvageable, and if not, then try to find a donor engine for it, or pass on the truck and keep looking. I'd rather not pass on it, because $2500 for an '06 with under 100k and exactly the style I'm looking for is a pretty sweet deal.
