94 E150 running rough
Old Feb 7, 2019 | 04:17 PM
donehojo's Avatar
donehojo
New to me 94 with 5.8. 126 k. New plugs, wires. cap, rotor, fuel filter, air cleaner, and fixed a few vacuume
leaks. Good fuel pressure. Hesitation when accelerating and jerks at speed. What could I look at next?
Old Feb 7, 2019 | 07:13 PM
wirelessengineer's Avatar
wirelessengineer
Coil, and associated wiring. Check the connection to the coil, too.
Also possibly the distributor itself. The shaft bearings can wear out. How did the old rotor and cap look? Bad dizzy bearings can cause the rotor to make contact with the cap, and things get ugly at that point.
Old Feb 8, 2019 | 08:16 AM
HandyAl's Avatar
HandyAl
  • Make sure your TPS is within specs.
  • Check capacitors inside the computer to make sure they have not gone bad.
Old Feb 8, 2019 | 05:43 PM
donehojo's Avatar
donehojo
The cap and rotor didn't look real bad. I think I'll go to the TPS next. Thank you both for some direction.
Old Feb 10, 2019 | 07:30 PM
donehojo's Avatar
donehojo
found a code for open spout. Found the spout down under the battery nest to an old oil cap. Runs much better now for some reason. HHAHA
Old Feb 11, 2019 | 07:00 AM
wirelessengineer
Spout?
Old Feb 11, 2019 | 05:00 PM
donehojo's Avatar
donehojo
xc4jokestomper
16
Jul 16, 2010 10:22 AM
kalamazoo
Apr 4, 2005 02:56 PM
numbertwentynine
Jul 8, 2004 08:57 AM
rusty70f100
Nov 17, 2003 12:25 PM
mrak
Mar 11, 2003 06:50 PM
