Help
Old Feb 6, 2019 | 02:15 PM
MikeT2351's Avatar
MikeT2351
Help
Never done one of these posts and not too much of a mechanic but know the basic so bear with me, yesterday morning my truck wasn't starting and at first I thought my batteries were dieng so I had them tested and all good, came back and put my batteries in and truck fired up and died about 30 seconds later. Then my truck threw a code that fuel rail pressure was too low so I ordered fuel filters and they are on the way. I turned my key about 6 times like I had just put new filters in and my truck ran fine the rest of day. Now today my truck is just doing one single click when I try to start it and saying service advancetrac on my dash. When I turn the key my glow plug light is not showing up on the dash. I was thinking my pcm may be bad or something but I have no idea. Please help!
Old Feb 6, 2019 | 03:53 PM
SavageNFS's Avatar
SavageNFS
Truck details? Year, engine?
What codes are being thrown?
Old Feb 6, 2019 | 04:15 PM
MikeT2351's Avatar
MikeT2351
2011 f250 6.7 P008A P0000 there was another code but I can't remember what it was and now my tuner won't communicate with my truck at all so I haven't been able to check the codes again
Old Feb 6, 2019 | 04:21 PM
SavageNFS's Avatar
SavageNFS
So the truck is tuned? This is kind of critical information. I would try returning the truck to stock on the tuner first. Do not attempt to start. Then reload the tune on the truck and see what happens. Sounds like your batteries are going. Weird they tested alright. What voltage are you getting when you try and crank?
Old Feb 6, 2019 | 04:27 PM
SavageNFS's Avatar
SavageNFS
Oh snap, I missed the part where you said your tuner won't communicate with the truck. What kind of tuner? Tunes? Have you tried unplugging the tuner and plugging it back in? Yes, I'm serious. I've had bad cords on tuners and a new cord solves all sorts of issues.
Old Feb 6, 2019 | 04:29 PM
MikeT2351's Avatar
MikeT2351
It's a bully dog, the cord for it is a little wore out so that could be an issue
Old Feb 6, 2019 | 04:30 PM
SavageNFS's Avatar
SavageNFS
I think that just uses an HDMI cord. Try swapping the cord.
Old Feb 6, 2019 | 04:31 PM
MikeT2351's Avatar
MikeT2351
Will probably end up taking it to local mechanic tomorrow just didn't know if it sounded like there was anything small I could be missing. Glow plug light isn't popping up so I thought for sure it had to be something to do with pcm so I have a new pcm relay showing up in the morning
Old Feb 6, 2019 | 04:32 PM
MikeT2351's Avatar
MikeT2351
Ok I'll try that
Old Feb 6, 2019 | 04:40 PM
SavageNFS's Avatar
SavageNFS
If your tuner isn't communicating properly, your windows could go up or down with your turn signal, not kidding. It can also brick a computer easily.
Old Feb 6, 2019 | 05:06 PM
MikeT2351's Avatar
MikeT2351
New cord still nothing, no check engine light. Just one click from passenger side when trying to start
Old Feb 7, 2019 | 06:36 AM
EO2SeaBee's Avatar
EO2SeaBee
Above and beside the parking brake pedal assembly (driver's side kick panel under the dash), there is a giant plug with a large grey locking lever on it. Locate the plug, and carefully release the grey lever, squeeze the two sides of the plug back together, then re-latch the grey lever.
rch10007
Dec 20, 2014 04:41 PM
a4t1rat
6.4L Power Stroke Diesel
Nov 26, 2012 01:35 PM
lude98r
Apr 29, 2012 12:24 PM
nmcqueen469
15
Jul 28, 2008 06:51 PM
96ford4x4turbodiesel
Jan 24, 2006 08:47 PM
