Sponsored by: Real Truck
Icp pigtail
Old Feb 6, 2019 | 11:17 AM
roberto.santamaria26's Avatar
Icp pigtail
Will a bad icp pigtail cause rough idle and a no start during cold temperatures?
Old Feb 6, 2019 | 11:30 AM
Colorado350's Avatar
Colorado350
Welcome to FTE.
Give us more information, Year, engine, mileage, symptoms etc. If you unplug the ICP on a 7.3 the PCM defaults to default settings, meaning the sensor and the pigtail is irrelevant. Typically in cold weather hard starts and rough idle is a combination of GPR and glow plugs not working properly AND a heavy weight oil being used as the oil warms the idle smooths out. Test your GPR and glow plugs. If you plug the truck in for 4-6 hours do the symptoms go away?
Old Feb 6, 2019 | 12:29 PM
Squirrel13's Avatar
Squirrel13
Cant a leaking ICP and oil soaked harness cause all sorts of issues?
Old Feb 6, 2019 | 12:30 PM
Originally Posted by Colorado350
Welcome to FTE.
My truck is a late 04 F-350 6.0 with 186xxx miles. I have already replaced the icp sensor and worked like magic. However, the following day when I went for a cold start ( truck was plugged in ). It started with a very rough idle and I can feel the truck shake judt like the idle sounds. Will definitely replace the pig tail and hope for the best. Now, my concerns are leading the the ipr valve. Also, upon accelerating my exhaust has a high pithed skipping sound.
MentalState
Apr 10, 2014 11:34 AM
grec-o-face
Apr 2, 2013 11:41 AM
SBFD8
May 5, 2008 09:22 AM
trakman
Dec 9, 2005 06:42 AM
chitownrepoman
Sep 5, 2004 08:06 AM
