Cold Start lope, why?
Old Nov 7, 2012 | 12:04 PM
grec-o-face's Avatar
grec-o-face
139k
Clean Oil
What are some things that will cause a lopey idle on cold start? If it sits overnight when its cold out (below 40F) - the next morning, it will crank over normally, and fire up with a VERY lopey idle. The lope will last about 10-15 seconds then idle normally. The idle doesn't 'smooth out', it just goes straight to normal idle.
I don't have a GP LED, but I can watch the voltage change (Aeroforce) when the relay disengages. And I wouldn't suspect the GPR because it fires right up - just doesn't idle smoothly.
Any thoughts?
Old Nov 7, 2012 | 12:20 PM
DND58's Avatar
DND58
Sounds like Romps. Can be caused by bad glow plugs or thick oil. Have you ohmed out your glow plugs, and checked to see GPR operation? Synthetic oil may help.
Old Nov 7, 2012 | 12:23 PM
Crewcab Turbo's Avatar
Crewcab Turbo
If you run synthetic 5/40 oil in the winter it will help prevent the Romps.
Old Nov 7, 2012 | 12:43 PM
grec-o-face
Originally Posted by DND58
Sounds like Romps.
Originally Posted by Crewcab Turbo
...help prevent the Romps.
How do I explain this to my wife???
(This could go down a very different path out of context)
15-40 Rotella. Same as last year, with No Romps.
I haven't ohmed the GPs yet. Guess I should.
Old Nov 7, 2012 | 12:52 PM
Crewcab Turbo
Could be a glow plug issue. The glow plug relays go bad often. I installed a led light in my gage pod to be able to see if voltage is coming out of the relay, it doesn't tell you if the glow plugs are working only the relay. At least you will know if your relay fails.
Old Apr 2, 2013 | 07:49 AM
grec-o-face
Update
Sounds like Romps. ... or thick oil. ... Synthetic oil may help.
To put this issue to bed...
I replaced the GPR with the AIH relay and it still romped. I then changed to 5/40 Delo synthetic and it hasn't romped once.
Old Apr 2, 2013 | 07:58 AM
howellt39's Avatar
howellt39
Thanks for posting the fix, had the same issue with persistent romps at medium temperatures and changing to 5-40 (Rotella though) cured mine as well.
Got close to twice the miles you do and old injectors are apparently a contributor.
Old Apr 2, 2013 | 08:20 AM
Tugly's Avatar
Tugly
There it is. With all the reading I've done on this, sticks age and they start to prefer soup over taffy in the winter.
Old Apr 2, 2013 | 10:20 AM
BillyBob69's Avatar
BillyBob69
HA!! Tell her its normal on cold starts to have romps unless the sticks are lubricated correctly. Then it all smooths out
I switched to Rotella T6 full synthetic and haven't had the romps since. My truck just went past 290K with the original sticks and still runs good. Complains a little if I start it without it being plugged in below 10 degrees but otherwise, no romps and runs smooth.
Old Apr 2, 2013 | 11:41 AM
howellt39's Avatar
howellt39
Gonna let that one slide...
roberto.santamaria26
Feb 6, 2019 12:30 PM
Keabler
38
Oct 25, 2017 05:31 PM
gungho351
39
Feb 16, 2011 09:35 PM
pog23
6.4L Power Stroke Diesel
Sep 4, 2010 04:25 PM
teg2_nv
Jan 28, 2009 07:40 AM
