Rolling/Loping Idle
Old Mar 4, 2019 | 09:00 PM
87crewdually's Avatar
87crewdually
Originally Posted by Justin Jones
Fired up perfectly this afternoon leaving from work. Fully warmed up I was seeing ICP fluctuating from 640 to 645. Is that the normal range?
Baseline I use when fully warmed up +186°f at idle, normal is around 588 psi @ 21% for a healthy system.
What was the IPR %? A low coolant temp. may show a higher ICP.
Old Mar 4, 2019 | 09:50 PM
Justin Jones's Avatar
Justin Jones
Ah, it was 192° EOT, I didn't have ECT showing. I'll check that next time. I can also get the reading on IPR then to.
Old Mar 5, 2019 | 06:22 PM
Justin Jones
Today 196° EOT and 190° ECT were pretty stabilized. IPR was steady at 23.5 and ICP was ranging from 580 - 586.
Old Mar 5, 2019 | 09:26 PM
theonlypheonix's Avatar
theonlypheonix
. But the truck runs good. There's a little bit of hint of a stumble at idle. I don't really know how to explain it. The idle isn't perfectly smooth.
While I ran T6 oil for most of the life of my 6.0L PS during which it had idled flawlessly for around 148K mi. Then at that point the engine developed a tick (sudden but momentary slight drop in RPM ) which only continued to get worse. A one point it seem as the injection would turn off for a fraction of a second but would again catch again before the rpm dropped below 300 rpm. This cycle would repeat on an irregular intermittent basis but otherwise ran strong while driving . Problem was resolved by replacing the ICP sensor, idled perfect again.
Old Mar 8, 2019 | 09:28 AM
Justin Jones
Thanks for the info. I think my ICP values look good after I let it warm up to check them. I don't see anything out of the ordinary with any codes etc.
I guess the title of the thread should be changed to Miss At Startup now. The first time I've started after full cold soak and it missed for about 2 seconds this morning leaving for work. It's a lot warmer today that it's been lately, even earlier this week. Funny thing is after using Forscan I thought I would get some codes or something. But I'm getting nothing.
How do I tell which injector is sticking?
Old Mar 8, 2019 | 09:37 AM
87crewdually
Before the first start of the day do an injector Buzz test with Forscan. During the test Listen for the audible clicks in rhythm, in order starting with cyl. 1, 2, 3...ect. If you dont hear a click make note what cylinder it was. Good chance that will be a faulty injector, possibly stiction.
Old Mar 14, 2019 | 12:24 PM
Justin Jones
Well I haven't had a chance to check the injector buzz test. What should ICP be during cranking? I noticed mine during cranking this morning jumped up to 1085 I think. I just barely caught it at a glance. Then once the truck fired it fell below to about 983 or so and that was during the miss. The idled smoothed about when it jumped back over 1000. I don't know if this is a symptom of a bad ICP sensor or a by product of the miss.
Old Mar 16, 2019 | 05:37 PM
Justin Jones
I ran the Forscan Lite KOEO Injector Electrical Self Test. I got codes for every injector. P0261, P0264, P0267, P0270, P0273, P0276, P0279, P0282. Then ran the KOEO On Demand Self-Test and got all of the same codes.
Is the Injector Electrical Self Test know as the injector buzz test? If I'm getting codes for ALL of the injectors that means FICM right?
Thanks for all of the help so far guys.
Old Mar 17, 2019 | 10:13 AM
Justin Jones
Thoughts anyone?
Old Mar 17, 2019 | 12:57 PM
bismic's Avatar
bismic
It probably means the FICM since those are circuit codes, but make sure the FICM harness connectors are FULLY seated and that there isn't a wiring issue!
Old Mar 17, 2019 | 02:22 PM
Justin Jones
Will do, thanks Mark. I knew I was having some FICM trouble when the weather was colder. I thought I was okay for awhile since it's been a little warmer. FICM repair will be my next stop.
Old Mar 18, 2019 | 09:23 AM
Justin Jones
Well I checked the connections on the FICM and they seemed like they wouldn't budge; all the way plugged in. But I may have made things worse because now I do have a check engine light on with P0202, P0261, P0264 and C2102, C2402. I can't seem to find anything out about the chassis codes.
navistarnut
Dec 2, 2015 08:30 PM
acf6
Feb 3, 2013 06:07 PM
rhodeisland350
Nov 5, 2008 12:38 AM
Troll
Sep 27, 2004 07:04 PM
S14
May 27, 2004 12:44 AM
