I've been around the towing and heavy hauling starting in 1978 and there is no way I would give up high hp truck motors that we have today for the old days just in the mileage gains alone and with my load with my 6.2 I run in OD all the time.
Denny
I agree... my motorcycle has 110 hp... my corvette has 490 at the rear tires......
I will never own a battery powered vehicle.
but the final differential is not the only answer.. but the DIFF has 90 plus years of development behind it... no one wants a change...
and I am NOT saying go to CHAIN.... but sticking with the diff.. can not get much better.
a Truck Transaxle in the rear.... transverse engine 8L gas,, flat 8 cylinder. under the bed..... no 90 degree..
and I did drive semi-truck a few years.....
a few years ago.. they were working on a Screw drive final system..
reason...
when an engine locks-up... the screw drive will fail, allowing rear wheels to continue to rotate.. less crashes..
stopped the research... to much "Cost" to bring into production.
The thing that sticks out to me is that the V10 is incredibly trouble free for the heavy duty application. For Ford to go to this much trouble to replace it you would think that fuel efficiency is the main goal. A little more power will be nice but I am betting efficiency is the main difference.
Thats a great point. The 3v design dates back to 2005, and the base engine 1998. So I’m sure we will see some improvement against that engine. The 6.2L is by most accounts significantly more efficient, especially when unloaded.
My V10 with 4.30s was incapable of hitting 12 MPG. I think 11.7 was my best tank.
maximize cylinder swirl .. 3 and 4 valve is harder to control swirl..
reason when possible.. direct injection is selected. and not behind a valve.. ( indirect injection )
being the 7.3L is single spark plug... swirl and flame travel is maximized without duel spark plugs.
all my guessing. no fact is known by me.
still interested in the odd intake system... throttle body under intake .. large upper arch runners.
I hope Ford is forthcoming with design information.
The number of valves does not control swirl. What controls swirl is the relationship of the running length and approach angle, valve shrouding and valve diameter/bore ratio. The reason multi-valve engines have become popular is that more valves make for a more efficient filling and evacuation in higher rpm applications. However, in lower rpm applications, having more valves is not necessary, so removing them aids in cost reduction with no penalty in cylinder filling. (less valves means less parts; not just the valves, but the valve springs, the rockers, lifters/tappets, cam lobes and all the machining to make those parts. it adds up to quite a lot).
As to the intake, that isn't hard to make a reasonable guess here. Two things jump out here:
1) by putting the runners on top, they can make they longer, with a smoother (larger radius) approach to the intake valve; these aid torque development at lower rpm.
2) it also has the effect of the runners staying cooler in applications running under heavy load. There is less mass to heat up in the throttle body than the runner, so keeping the runner cooler (where more contact surface exists long the walls of the runner) means a cooler charge.
Yep, I think Chuck is right on this one. My old Contour had a similar system, and when it broke there was a huge difference in how it drove. When stuck open it wouldn’t even start, but when stuck closed it had no power at higher RPMs.
My Pacifica has an even slicker system that was introduced with the 2nd Gen Pentastar. It uses a dual-lift cam profile on the intake cams that shifts to high lift above 3,000 RPMs. This system is credited for a 15% torque increase below 3K.
adjustable intakes.. adjustable cam lift/duration.. all helps.. for each area.. = a more useful engine.
just like adjustable compression.. adjustable displacement..
as is the 6.2 L.. adjustable camshaft timing... its even considered Old by today's standards...
The 3V 5.4l did, which was used from 2005 – 2010 in the Super Duty. It was introduced in 2004 for the F150, and has been plagued with issues with the VVT system. Most manufacturers got these right the first time around, but this system was a disaster by most accounts.
Ford eventually figured it out. The 6.2L has VVT and it doesn't have any issues.
Ford and everybody else. I'm not aware of any engine production engine that doesn't have this technology. The system using the 3-valve modular engines has been the only one I've ever heard to have issues, the others all seem to be pretty much bulletproof. I think VVT is a big reason why modern engines all have a much wider torque curve then the dinosaurs of yore.
That's one of the big benefits of DOHC designs, as the new ones can independently control the intake and exhaust cams. Which makes for an incredibly flat torque curve from low RPMs that usually screams all the way to redline.
The 3.6L Pentastar engine in my van completely embarrasses the 4.6L V8 I had in an old Town Car that weighs about the same. Modern engine controls can do some amazing things.
bean counters inside corporate... destroyed more then one good idea..
Like the < no name > steering column ignition switch..... to save 50 cents a car
im assuming the cam phasers were the problem. still a decent amount of work to replace but even worse in a transverse engine like in other models like 3.5l ti-vvt ford edge.
