Sponsored by: Real Truck
Rough ride.
Old Feb 9, 2019 | 10:51 AM
  #31
jav_eee's Avatar
jav_eee
Originally Posted by Celtictexan
I tried the 60/45 and it's a world of difference. Drove to town today and I'm pretty sure all four tires were on the ground at all times. Now what to do about that low pressure light......
OBD2 adapter and Forscan.
Old Feb 9, 2019 | 02:08 PM
  #32
Celtictexan's Avatar
Celtictexan
Thanks. Hopefully ford will do it for me.
Old Feb 10, 2019 | 09:32 AM
  #33
jav_eee's Avatar
jav_eee
I doubt they will. Same reason why they instruct you to run at max psi all the time. Liability. Even forscan pops up a warning about not setting it lower than the setting on the door placard. You're gonna have to do this one yourself.
Old Feb 10, 2019 | 10:24 AM
  #34
speedfreak78's Avatar
speedfreak78
You should chalk new tires to set the correct unloaded air pressure. If you run the door sticker pressure all the time your tires, especially the rears, balloon, or convex, and wear the center treads faster. It doesn't really work for used tires, as the tread has already worn to the air pressure is been run at. With old tires, to even the tread and find the best pressure, you can measure tread depth across the tire, if center depth is shallower than the edges, lower pressure to concave the tire. If the center tread is deeper, raise pressure to convex the tire.
How to chalk a tire :
https://www.intercotire.com/using_ch...etermining_psi
Bassboatman
Nov 21, 2016 01:51 PM
Loopy
Nov 30, 2010 01:19 PM
Borch1
Feb 26, 2008 10:40 AM
Flux
Mar 19, 2007 01:42 PM
EZ-Ford
Jan 8, 2007 11:17 AM
