Re-use a 300 6cyl from a '94,
I assume the '94 uses a PCM to run the fuel injection, how many sensors does the PCM need to make it run right?
Any hiccups (aside from physical connections) to expect since I want to put it in an older truck (1985 F150 2WD Auto C6) maybe the older C6 will need to be replaced with a more modern one?
thanks
thanks
thanks, I only found an engine (complete) and it was $75 so I thought I would be well on my way but pulling all the wiring and the dash in the cab wasn't what I was thinking, I'm sure I would have my hands full with just getting the engine and trans in... I would give it a try if the perfect parts truck was dropped off in my driveway for sure! hehe
How about a standalone MegaSquirt / Microsquirt? Cut up the donor harness, pare it down to the minimums and let 'er rip! You can leave all your factory chassis harness stuff in place and just let the EFI system be separate. You'll have to add a high pressure fuel system with either swap you're proposing...
captain1997
12-15-2014 02:55 PM
strokin'_tatsch
05-18-2012 05:36 PM
ReadOrDie_WoW
Ford Truck Parts for Sale
33
02-21-2010 02:42 AM
