94 Engine wiring harness
Old Dec 3, 2007 | 08:52 AM
Fanboy's Avatar
Fanboy
I just got done putting a 94 302 5.0 into my 92 F-150, and i was wondering if I would be able to use the engine wiring from the 94, instead of re-useing the 92 wiring harness, and if not, why? The harness from the 92's 302 is a pretty good hack job, and i would really rather not use it.
Thanks!!!
Old Dec 3, 2007 | 06:18 PM
lostin90s's Avatar
lostin90s
You may need to .
As the 94 firing order may be different than the 92 you have. May have to repin some . All sensors should be same . I know other than sensor moved to air box on my 94 But its a MAF truck . Everything else was same. I think only MAF equipped trucks are sequential injection. (a wire for each injector.) Just compare wire placement in plug and # of wires
