Wastegate actuator
Old Feb 3, 2019 | 08:00 PM
rriddle99's Avatar
rriddle99
Wastegate actuator
I broke the wastegste actuator. Looking for a replacement. Should I go to a 33psi unit? Was thinking of disabling it altogether anyway. Engine is 2002 stock with tps 6 position chip. I rebuilt turbo and swapped the compressor wheel with a 5x5 wheel however when attempting to adjust the length of wastegste shaft it broke.
Thoughts?
Old Feb 4, 2019 | 07:50 AM
Walleye Hunter's Avatar
Walleye Hunter
I would just remove it and plug the lines to it, unless you're in Kommieforina where you'll probably have to fix it.
Old Feb 4, 2019 | 07:54 AM
HD Rider's Avatar
HD Rider
Welcome!
If you are located outside of California and don't have to deal with smog inspections, get a mechanical unit from dieselsite.com.
https://www.dieselsite.com/19995-200...ontroller.aspx
If you are from California, get a Banks Big Head. It has an EO# and is California smog legal.
https://www.riffraffdiesel.com/bighe...uator-99-5-03/
These are an upgrade from stock. The one from Diesel Site is adjustable.
If you are on a tight budget and just want to stay stock, Riffraff has that too.
https://www.riffraffdiesel.com/waste...uator-99-5-03/
Let us know what you do and how it works out.
Old Feb 4, 2019 | 08:59 AM
rriddle99's Avatar
rriddle99
Thanks for the responses.
What issues can I run into by not using the wastegate seeing as how I have the TPS chip?
Old Feb 4, 2019 | 10:08 AM
Walleye Hunter
My truck is live tuned, PO disconnected the wastegate and I now run a van turbo, which has no wastegate so I can't tell you the differences but I can tell you that my truck runs fine.
Old Feb 4, 2019 | 12:27 PM
HD Rider's Avatar
HD Rider
With stock injectors you won't have any problems.
Old Feb 6, 2019 | 03:05 PM
HueyCrew's Avatar
HueyCrew
I have the 33psi also waiting on warmer weather to rebuild the turbo. My rod end seems way too tight on the shaft. It ought to be able to be hand-threaded but it's locked down tight although the lock nut spins freely. It's generic off eBay so we'll see.... Replacing the pedestal, going to the 360 bearing kit and swapping the EBPV housing for a delete one and adding a 5X5 billet wheel. Have been pondering the TS6 myself but have "overthunk it" a bit since reading reviews and the horror stories about it (and other tuners) that weren't bought direct from the makers. I'm going to follow along with this and look forward to seeing how it all turns out for you.
Old Feb 12, 2019 | 01:53 PM
rriddle99's Avatar
rriddle99
Thank you all for the responses. It is my plan to wire the wastegate closed and plug off the line. I'm installing all new boots and clamps, rebuilding the turbo, changed the pedestal for the EBPV delete, changed the turbo housing to remove the EBPV ,changing the HPO lines and adding a cross-over line and replacing the up-pipes. Right now I'm stuck between life moments and the fact that I had to cut all 4 bolts that held the up pipes to the manifolds and they are "welded" to the manifolds. I've been unable to get them out thus far. I've soaked them repeatedly with penetrating oil and have been using an air chisel but no luck. Once I get them out I'll get it all back together and report back how it does in this configuration.
Old Feb 12, 2019 | 01:55 PM
Walleye Hunter
I had to heat mine with an acetylene torch to get them out of there. Cherry red.
Old Feb 13, 2019 | 05:21 AM
FordTruckNoob's Avatar
FordTruckNoob
A safer option for heating the bolt that is less likely to set fire to other stuff around it is an induction heater like this:
Bolt Buster BB2-ACC Orange/Black Handheld Heat Induction Tool
Amazon Amazon
They are stupid expensive though so you may want to try building your own:
https://www.instructables.com/id/100...uction-Heater/
Old Feb 13, 2019 | 07:02 AM
RigCity's Avatar
RigCity
You will see there are 4 open areas on the bolts they are there so you can cut the bolt w a metal wheel they are single use bolts that have cut threads so they do not back out/unbolt easy
Old Feb 13, 2019 | 07:55 AM
Dan V's Avatar
Dan V
You still have to remove the frozen portion of the bolt from the manifold. And cherry red heat is your friend.
Old Feb 13, 2019 | 08:11 AM
Walleye Hunter
I use old license plates for heat barriers when heating in sensitive areas. I also had the starter out on the driver's side, it gave me extra room. Oh, and I had both fender liners out for better access.
Old Feb 13, 2019 | 08:30 AM
Jschon's Avatar
Jschon
If there is enough of the bolt still sticking out of the manifolds, you could try welding a large bolt or nut to them. Might give you enough torque to get them out, and would heat them in the process.
Old Mar 26, 2019 | 03:29 PM
rriddle99's Avatar
rriddle99
Thanks everyone. I'm beyond frustrated at this point. I bought an acetylene torch kit to help and still no go. I'm able to melt the nut end of the bolt but I cannot get to it at the right angle to make a difference. I think now I need to figure out how to weld something to the end of the nut/bolt and see if that will help. I do not feel confident in this as these things are STUCK!! I've even thought about cutting the manifold out and using a u-bolt to connect to the up-pipe flanges but I can see where the heat/cooling cycles will make this a constant maintenance item. Other option is to cut the bolts holding the manifold to the block and hope none of them are stuck in the block. Once the manifold is out I can get the bolts out or replace them if necessary. Most everything else on this truck has been fairly easy until this. Again, once I get these taken care of I'll be able to get it all back together and report back to the group. Any other suggestions on how to get stuck bolts out would be welcomed as well. The only welding option I have is this new torch...
woodnthings
41
May 28, 2014 05:11 PM
mxracer3276
16
Sep 16, 2009 08:29 AM
pwrdbyjp
Sep 9, 2007 02:03 PM
wolfe1104
20
Feb 5, 2007 06:17 PM
crack
16
Oct 6, 2006 08:29 AM
