1958 harmonic balancer
Old Feb 1, 2019 | 05:26 PM
bjano00's Avatar
bjano00
so looks like my inertia ring blew the rubber seal and is now hanging off the back of my balancer against the engine block. Is this thing toast or can it be rebuilt? Found a few new ones that don’t have great review. One review even states there are no timing marks.
Old Feb 1, 2019 | 06:05 PM
Tedster9's Avatar
Tedster9
Power Bond makes a quality unit, part #1199N about $250 from Summit or the usual suspects. There are a couple rebuilding services that can fix you up if going that route.
Old Feb 1, 2019 | 08:49 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
One type does not fit all! What size is the engine, 223 I-6 or 272/292? How many pulleys does the balancer contain?
Old Feb 2, 2019 | 01:06 PM
bjano00's Avatar
bjano00
It’s the 292 with a single belt
Old Feb 2, 2019 | 03:21 PM
NumberDummy
It’s the 292 with a single belt.
C3TZ-6312-E .. Crankshaft Pulley includes Harmonic Balancer (damper) - Single Sheave - 6 3/8" O.D. - 6 1/4" damper, 4 1/2" long. (2) 3/8" -16 holes, 15 timing marks / Obsolete
1957/64 F100/700 & C550/700 Tilt Cab & P350/500 Parcel Delivery with 272/292 and single sheave harmonic balancer. There was also a double sheave balancer.
No Ford dealer or obsolete parts vendor has any, none on ebay.
A private source in Olathe KS has 1 .. Go to rearcounter.com and type the part number and the contact info will come up.
Old Feb 2, 2019 | 03:43 PM
G-Force junky's Avatar
G-Force junky
Wow NumberDummy you are the heart and soul of this forum!!!
hope you stick around a while lol
Old Feb 2, 2019 | 04:34 PM
bjano00's Avatar
bjano00
Hope to not come off as rude as it’s obvious you know a hell of a lot more than me but Why won’t the Dayco PB 1199N part work? It is even recommended by on John Mummerts ford-y-block.com as a replacement for the obsolete original
Old Feb 2, 2019 | 04:53 PM
NumberDummy
I said nothing about it, and I know nothing about it, because it's an aftermarket part.
I listed the Ford part number and the specs after you said what size the engine was.
Tedster9 jumped the gun by assuming it was a Y block when he gave you the info. It would have been the wrong part if it was a 6 banger.
I learned many moons ago that you cannot assume anything, especially when it's related to FoMoCo and owners of their vehicles, some of which...when asking questions...fail to list some/all the pertinent info!
Old Feb 2, 2019 | 05:21 PM
Tedster9's Avatar
Tedster9
I didn't leap on any firearms Bill nor make any assumptions, he was looking for a 292 V8 damper on another thread.
Power Bond 1199N is (still) probably the way to go. NOS, even if he were to find one, is likely to suffer the exact same problem as the one he has now. Plus they probably want a small fortune for it. When RearCounter sez one (1) is available - typically nobody ever has one. I think it's a placeholder or some ******* didn't update the inventory etc.
There are a couple damper rebuilding services too if you look online. "Damper Dudes" etc.
Old Feb 2, 2019 | 06:00 PM
NumberDummy
OP failed to mention that in this thread, and you didn't say anything either.
So, how the hell would I or anyone else know it has a 292?
Go out a fire about 5 rounds of .35 Remington in a Remington Model 8 without a recoil pad or a Pass recoil shield.
This semi-auto rifle and caliber killed Clyde with one shot, it will kill your shoulder too!
Old Feb 2, 2019 | 09:21 PM
Tedster9's Avatar
Tedster9
OP failed to mention that in this thread, and you didn't say anything either. So, how the hell would I or anyone else know it has a 292?
Well the OP had a whopping total of two (2) posts on FTE at the time. So I took the the time to read it. I did "assume" he knows what he's looking for.
I had a roomate in school whose parents had $$$, he liked to collect firearms. Expensive firearms. One of them was a Sako something something (.375?) H&H elephant gun. I shot it at the range once. That was enough. No practical purpose in North America I don't believe. I like plinking stuff, no tin can is safe around me! Plus I can afford to you know, actually shoot it.
Old Feb 2, 2019 | 11:08 PM
bjano00's Avatar
bjano00
Thanks guys. I appreciate the help
quakerj
Aug 13, 2013 09:19 PM
re54drider
Mar 19, 2006 08:05 AM
bobbarob
Jun 1, 2003 11:24 PM
Hawkeye58
Feb 21, 2002 10:39 PM
