towing package
Old Jan 31, 2019 | 07:58 PM
dremtofford's Avatar
dremtofford
towing package
i need the electrical part(relays, plug ins, ect.) the p.o. just stripped the wires in the tail light lense and wrapped tape around it, no relays, no fuses just two bare wires hanging out.
Old Feb 1, 2019 | 12:04 PM
shorod's Avatar
shorod
You don't mention the year or model of your truck, but for several of the model years there is a factory-provided pigtail near one of the tail lights that has all the wires needed for a 4-wire trailer connector available. With those setups you can purchase a trailer wiring harness adapter from most chain auto parts stores that will plug right in to the pigtail and has the correct amount of wire length to safely route the wires to your receiver.
-Rod
Old Feb 1, 2019 | 12:16 PM
dremtofford
it is a 91 eddie baur edition. it has the reciever hitch but no trailer wires. do i need relays or fuses for the trailer wiring?
Old Feb 1, 2019 | 05:13 PM
shorod's Avatar
shorod
If your '91 has the pigtail already, the relays and fuse protection is already part of the fuse/relay panel. It appears the pigtail was installed at least on some '91 Explorers so it's worth looking in to. For around $20 you'd get a clean install that includes the 4-wire trailer connector. Here's a link to what I'm referring to. That link mentions "behind driver's side taillight" but in my '97 Mountaineer it was located underneath the driver's side taillight. It didn't require removing the taillight, only crawling underneath and pulling the rubber plug out of the connector so that I could plug the pigtail in.
-Rod
Old Feb 2, 2019 | 01:12 AM
dremtofford
i don't know i didn't see the round plug but it has been dark or raining when i went and checked.
Old Feb 2, 2019 | 07:11 AM
shorod's Avatar
shorod
In your case then you might need the Curt version at the link I provided previously. If you click on that product and look at the installation instructions it shows where to find the connector for that version and how to install it. While not ideal in my opinion, this is still a much better approach than having the two wires just dangling like the previous owner did.
I'm not sure if this approach will lead to hyperflash of the turn signals when a trailer is connected or not. As far as fuse/relay protection, you'll at least get fuse protection through the normal fuses for the taillights. I'd offer to check the wiring diagrams for the taillights to see if this would likely cause hyperflash but unfortunately my Ford service manuals only go back to 1992.
-Rod
Old Feb 2, 2019 | 11:17 AM
dremtofford
thans that helped a lot. i think i can figure out the relays and such. thanks again it is one more step to the end product.
Old Feb 3, 2019 | 01:57 PM
dremtofford
went to pull and save the other day and found a 94 with the trailer plug it was on the passenger side and was square will this work on my 91?
Old Feb 19, 2019 | 10:46 AM
dremtofford
the weather cleared up a bit and i crawled underneath and found the round plug with the plastic plug still in it and i plugged my found harness in and it fit like a glove, yeah that is one step down.
BridgerDog
Oct 1, 2018 10:31 AM
DetailerDave
All Things Towing
28
Sep 18, 2013 01:09 PM
93 mix 'n match
1997 - 2003 F150
May 24, 2010 05:20 PM
slinger34
All Things Towing
Mar 1, 2009 12:13 AM
cecoen
Jul 20, 2007 08:36 PM
