melted wires at trailer plug in.
what kind of trailer & plug do you have? does the trailer have it`s own battery? usually a fuse should blow before getting the wires that hot, however while walking by my dad`s 5th wheel one time i heard a clicking noise, traced it back to where he throws his 7way connector in the pin-box, it grounded out on the battery charge wire & the relay just kept kicking in & out heating the wire up to where it melted some insulation.
Loose wires/corroded wires/bad grounds can be bad and start the melting process and even fires.. My dad got home for work one day and parked his truck in the garage. Thought he may have left a garage light on. Went back out and smelled smoke. His trailer connection had corroded so badly that it almost caught on fire.
Firefighter 1406
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
26
10-26-2016 01:52 PM
2kcrewcab
6.4L Power Stroke Diesel
13
04-07-2011 06:04 AM
