replace headlight switch
Old Jan 27, 2019 | 11:34 PM
tiltoe's Avatar
tiltoe
I am new to the forum and to working on ford trucks. I am looking for help with the headlight switch. What is the difference between serial number before 25000 or after 25000? Is it the last numbers on the vin? any help will be grateful. Just want to get the right switch.
Old Jan 28, 2019 | 12:04 AM
meangreen92's Avatar
meangreen92
What year is the truck? Probably either switch will work fine, but hopefully someone else will know what the difference really is.
Old Jan 28, 2019 | 12:08 AM
tiltoe's Avatar
tiltoe
It is a 76 f250 ranger xlt
Old Jan 28, 2019 | 04:05 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
I have never seen where a serial # of a truck matters on the headlight switch. So when you went to the parts store they asked you the truck serial #?
Something I found....
Sample VIN: F10AU100001
First three characters - F10 - Truck Series Code
F10 - F100 2 Wheel Drive
F11 - F100 4 Wheel Drive
F14 - F150 4 Wheel Drive
F15 - F150 2 Wheel Drive
F25 - F250 2 Wheel Drive
F26 - F250 4 Wheel Drive
Fourth character - A - Engine Code
A - 6 cyl - 240cid - 1BBL carb - 1973-74
B - 6 cyl - 300 cid - 1BBL carb - 1973-80
G - V8 - 302cid - 2BBL carb - 1973-80
H - V8 - 351cid - 2BBL carb - 1973-80
Y - V8 - 360cid - 2BBL carb - 1973-76
H - V8 - 390cid - 2BBL carb - 1973-76
M - V8 - 390cid - 4BBL carb - 1974-78
S - V8 - 400cid - 2BBL carb - 1977-80
J - V8 - 460cid - 4BBL carb - 1973-80
Fifth character - U - Assembly Plant Code
B - Oakville, Ontario, Canada
C - Ontario, Canada
E - Mahhaw, NJ
H - Lorain, OH
I - Highland Park, MI
K - Kansas City, MO
L - Michigan Truck
N - Norfold, VA
P - Twin Cities, MN
R - San Jose, CA
S - Allen Park, MI
U - Louisville, KY
V - Kentucky Truck
Remaining six characters - 100001 - This is a numeric code for the vehicle build sequence. In some cases there could be two letters and four numbers.
To get a walk thru on how to remove the headlight switch stud and **** to get the dash bezel off to get to the switch go here. And welcome to FTE. You do not have to remove your instrument cluster just the bash bezel.
https://www.ford-trucks.com/forums/showpost.php?p=14880899&postcount=66
And https://www.ford-trucks.com/forums/showpost.php?p=14982704&postcount=78
Old Jan 28, 2019 | 09:35 PM
tiltoe's Avatar
tiltoe
I have never seen it either. I just pulled the switch out and ran the motorcraft part number. thanks for the info on the vin numbers
Old Jan 29, 2019 | 12:49 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
^ Y'all may never have seen a headlamp switch that the VIN is required to get the correct one, but it does matter in this case since the OP has a 1976.
"I've never saw a purple cow, I never hope to see one. But I can tell you anyhow, I'd rather see than be one!" -Gelette Burgess, famous 19th century San Francisco raconteur.
What is the difference between serial number before 25000 or from 25000?
Serial number is the last 6 digits of the VIN
1967/77 begin with a letter followed by 5 numbers. 1978/80 begin with two letters, followed by 4 numbers.
D3ZZ-11654-A (replaced C5DZ-11654-A; C5TZ-11654-A, B & C; C5ZZ-11654-A; C8UZ-11654-A; D1ZZ-11654-A and etc.) .. Headlamp Switch KIT (Motorcraft SW-1245)
1965 Falcon / 1965/66 Mustang / 1965/66 F100/1100 / 1967/72 F100/750 / 1969/75 Econoline / 1971/72 Mustang/Cougar // 1973/75 F100/350.
1976 F100/350 & Econoline before serial number C25,000.
D7TZ-11654-A .. Headlamp Switch (Motorcraft SW-1381) / Marked: D7TB-11654-AA
1976 F100/350 & Econoline from serial number C25,000 / 1977 F100/350 & Econoline.
bigsnag
13
Aug 8, 2013 05:47 PM
spikinfool05
Feb 10, 2012 10:40 PM
rowdy16
Apr 19, 2010 07:29 PM
old_man_winter
Sep 21, 2006 04:35 PM
