That’s a big clevis! Stop by your local John Deere dealer. He’ll have some smaller ones so you can see if they fit before you buy them. Probably cheaper too! I got lucky and all three of my trailers have hooks that fit so don’t have any first hand knowledge!
A 5/8" shackle is what you want, and is what I use.
YES!
The 3/4 were a hair to large. Had to visit 2 TSC stores to buy. One was out of stock.
Some day will paint black, for now they have the mini-pearl tags flapping in the wind...lol
Some of the shackles suggested have load limits <7,000 pounds. Assume we are towing 10,000 pounds. Since one chain will be shorter than the other there will be 10,000 pounds on one shackle rated for 7,000 pounds.
Check out hammer locks, its what i bought and they are great. Easy to install and rated for 21k, had mine chromed though, couldn't stand the yellow color they came.
Is there something I don't get?
Might be wrong but I saw it as having to cover roughly the tongue weight + some given the shift in weight distribution if the trailer becomes unhitched. With 1500 lb tongue you'd need over 4x the amount of weight shifted forward from unhitching to get to the WL capacity of the shackle. Then again now that I think about it.... I guess that doesn't cover the impact load exerted by unhitching...
To be honest I was also considering you'd share the load between two shackles... Didn't realize chains were different lengths - is that standard?
