Odd idle
Old Jan 24, 2019 | 10:52 AM
reddogg94602's Avatar
reddogg94602
Odd idle
Hi there I'm trying to figure out what causing the odd idle on my 71 F-250 with the 360.
It's has a new distributor and rebuilt carb and new timing chain. I saw a thread that mentioned the springs in the distributor can break.
any thoughts? The odd idle is it will run but not accelerate then all of sudden it runs just fine.
Thanks.
Old Jan 24, 2019 | 11:56 AM
351Cleveland C4's Avatar
351Cleveland C4
Can you give us more detail as to when it does this?
Will the engine rev up in neutral? Does it only bog down when you're trying to drive?
And Just because parts are new, doesn't mean that they are good or adjusted properly.
Old Jan 24, 2019 | 12:03 PM
reddogg94602
Odd idle
Hi there it does all the time.
I tap on the distributor and it went away?
Couldn't repeat that gonna try a vacuum pump and see if reacts.
Old Jan 24, 2019 | 12:05 PM
351Cleveland C4
Do you have a vacuum advance? Is it hooked up properly?
Do you have any vacuum leaks???
Old Jan 24, 2019 | 12:09 PM
reddogg94602
Odd idle
None known, single vacuum
Old Jan 24, 2019 | 01:39 PM
Tedster9's Avatar
Tedster9
Process of elimination: Verify "0" TDC mark on the damper is indexed correctly. This is a very common defect. Sounds like a lot of parts were replaced, was this checked? Makes tuning/timing problematic due to faulty assumptions. Not unusual to see ignition timing 10° or 20° off from where it should be when this happens. Needs a new damper if this is the case. A piston stop tool is the best way. Even new aftermarket dampers can be off by a few degrees. Marking or verifying the exact TDC is important for baseline.
An easy check if there are questions about the distributor; run it up in neutral with a timing light put it through the paces from idle to 3000+ RPM (be VERY careful of the radiator fan) and verify the mechanical advance is working smoothly up and down the RPM range and doesn't stick. Make this test with the vacuum advance port disconnected and plugged. It should top out around 36° BTDC.
Old Jan 24, 2019 | 02:00 PM
reddogg94602
Odd idle
Doesn't matter if vacuum is hooked up or not
Old Jan 24, 2019 | 02:27 PM
Tedster9's Avatar
Tedster9
I apologize, guess you got 'er all figgered out then.
Old Jan 24, 2019 | 02:30 PM
reddogg94602
Odd idle
It's an old simple truck shouldn't be this hard to figure out.
im going to check the timing.
Old Jan 24, 2019 | 03:15 PM
351Cleveland C4
They are simple machines, but diagnosing them can still be a pain in the ***.....
Old Jan 25, 2019 | 05:02 PM
MIKES 68 F100's Avatar
MIKES 68 F100
if it is the same with vacuum hooked up and not hooked up then i think you found the problem .
Old Jan 25, 2019 | 05:21 PM
reddogg94602
Odd idle
I'm replacing the distributor and see what happens.
it's under warranty so no more $ spent and one more thing I eliminated as a cause.
Old Jan 27, 2019 | 03:42 PM
reddogg94602
Odd idle
It's fixed 😁😁😁😀😀😀
Old Jan 27, 2019 | 04:37 PM
351Cleveland C4
Originally Posted by reddogg94602
It's fixed 😁😁😁😀😀😀
Cool.
Care to elaborate?
Old Jan 27, 2019 | 04:39 PM
reddogg94602
Odd idle
Replaced the distributor and that's all it took.
drive in town with no problem.
ez1134
May 23, 2017 06:44 AM
Old Brown F250
15
Feb 12, 2014 04:59 AM
NW 150
18
Apr 3, 2012 08:05 PM
ErrorS
Oct 17, 2007 09:21 PM
72_ford
Feb 14, 2002 09:07 AM
