Help I.D. this wire
Old Jan 24, 2019 | 02:22 PM
eric8's Avatar
eric8
Help I.D. this wire
I've got a wire not hooked up to anything on a 72 F100 with the 302. Any ideas what it goes to? It has a style of connector that's normally attached to some type of sending unit. The wire comes off of the 3 wire plug off the firewall. The other 2 wires in this harness that ARE connected are going to the temp sending unit in the front of the intake and the red wire to the coil.
Old Jan 24, 2019 | 03:32 PM
JDFan4010's Avatar
JDFan4010
My three are going to Coil, Temp sensor & Oil Pressure sensor. hope that helps.
Old Jan 24, 2019 | 03:49 PM
eric8's Avatar
eric8
Ok thanks. Does yours have the oil pressure gauge in the instrument cluster or just the oil pressure warning light?
Old Jan 24, 2019 | 04:01 PM
351Cleveland C4's Avatar
351Cleveland C4
That'd be for the oil light, bottom right side of instrument cluster.
Old Jan 24, 2019 | 04:03 PM
JDFan4010's Avatar
JDFan4010
Factory gauge in instrument cluster.
However I've since put on an electrical gauge cluster for all 3 as they we're all bad.
Old Jan 24, 2019 | 05:34 PM
eric8's Avatar
eric8
Pardon my ignorance as I've just bought this truck and the electrical system is totally "dead" right now (still troubleshooting) so I can't even see my instrument lights. So these trucks have both a mechanical gauge in the cluster AND a low oil pressure dummy light? The lower driver's side of my block has an oil pressure sending unit, but it has a metal tube coming from it going to an aftermarket oil pressure gauge under the dash. Did the factory oil pressure gauge (not dummy light) in the dash use the same hard metal line setup?
Old Jan 24, 2019 | 05:48 PM
351Cleveland C4
No, it was an electric sender that ran the original gauge
Old Jan 24, 2019 | 06:00 PM
eric8's Avatar
eric8
Ok thanks. I'm wanting to get the factory stuff working so looks like I'll be ditching the mechanical oil tube and aftermarket gauge, buying an electrical sending unit, and getting the unit in the cluster working as designed. Thanks!
Old Jan 24, 2019 | 06:06 PM
FECruzer69's Avatar
FECruzer69
Someone has removed the original sender and installed an aftermarket mechanical unit. That wire will be for the factory warning light or gauge, whichever your truck was equipped with originally. Solving wiring issues can be a real pita, hopefully it won't be too bad.
Old Jan 24, 2019 | 06:44 PM
eric8's Avatar
eric8
Yeah, it's all starting to make sense now thanks to you guys. When a previous owner makes "upgrades" it's often hard to figure out what is going on!
Old Jan 25, 2019 | 08:49 PM
1TonBasecamp's Avatar
1TonBasecamp
Have a picture of the existing fitting with tube? Just so you know, the factory setup was an extension from the block, out about three inches and then the bell-shaped sending unit was threaded into that.
The factory extension looks like this: https://www.wildhorses4x4.com/produc...ronco_Oil_Pans and can be made from steel or aluminum. Even though both work, the steel is much better. I can't tell you how many broken aluminum ones I've seen over the years.
Mine actually had a round tube, but since I've never seen a round tube listed as factory even in earlier years, I'm guessing the one on my '71 bit the dust before I got the vehicle and someone had replaced it.
Ford even made some with two threaded holes. This would be most desirable from my standpoint, as you could have both a factory gauge and something else, such as an oil pressure cutoff switch for an electric fuel pump, or an added light, or whatever.
Oh, and the sending units for lamps vs gauges are different. However, I do believe that at least some companies use the same body, so they look identical. If your gauge does not work after installing one, it's either bad, or is for a lamp instead.
Paul
Old Jan 25, 2019 | 08:51 PM
1TonBasecamp
Of course, if the gauge does not work after installing the sending unit, it might still be something else entirely. Since none of the gauges work it sounds like(?) then it's probably the IVR (instrument voltage regulator, or "constant voltage supply" per Ford in the old days), or the printed circuit board on the back of the cluster, if your year has that.
Something that all three gauges have in common would be the first culprit to hunt down. That would be the power supply.
But after so many years, nothing says that all three might have had failures of components at different times. Only time and testing will tell the tale.
Paul
Old Jan 26, 2019 | 03:30 AM
eric8's Avatar
eric8
Thank you for that info Paul. Great to know!
Old Jan 28, 2019 | 11:18 AM
JEFFFAFA's Avatar
JEFFFAFA
Old Jan 28, 2019 | 11:22 AM
JEFFFAFA's Avatar
JEFFFAFA
Winfield1990
Jan 15, 2017 03:51 PM
Chris71f250CS
Dec 21, 2016 01:37 AM
billymfh
Sep 11, 2009 12:22 AM
olfordsnstone
Jul 11, 2005 06:59 PM
aztec
Sep 23, 2003 10:49 AM
