Resurrecting The Monster - My '05 Excursion
Old Jan 28, 2019 | 09:30 AM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
I should have time to get it back running this week, the one question NO ONE has answered or even formed a consensus on is: Should I run water first to flush things out? Or just run coolant and let the coolant filter and oil cooler do their job?
Old Jan 28, 2019 | 09:56 AM
SmackDaddy's Avatar
SmackDaddy
I’d figure out a way to flush with distilled water. Maybe force it through with compressed air so you don’t have a bunch of crud clogging your oil cooler once you get the truck running. You know how I roll...
Old Jan 28, 2019 | 10:30 AM
TooManyToys.'s Avatar
TooManyToys.
It's a hard issue to comment on. It's the same installing an oil cooler and then figuring out if you should flush. The good thing is that any rust particles should be caught in the input of the oil cooler, and being hard particles have the potential to be reverse flushed out.
Old Jan 28, 2019 | 11:11 AM
FiznUKa's Avatar
FiznUKa
Has anyone tried to fit a stainless steel mesh filter basket in the inlet of the oil cooler to catch the particles before they enter the cooler?
Old Jan 28, 2019 | 11:28 AM
TooManyToys.
t kind of already does that. You just have to backflush it out of there. And that's a tricky pathway.
Old Jan 28, 2019 | 01:58 PM
87crewdually's Avatar
87crewdually
Everytime I'm in the sprayer section of Tractor supply I wonder if these screens would fit but I never measured. But then again the intake side of the cooler isn't as easy to get to as the output so cleaning it would be an issue unless a back flush is enough to clear the screen.
Old Jan 28, 2019 | 02:51 PM
TooManyToys.
Amazon Amazon
Old Jan 28, 2019 | 03:19 PM
SmackDaddy's Avatar
SmackDaddy
Is that housing made from diamond dust?!?
Old Jan 28, 2019 | 03:22 PM
TooManyToys.
May be. There are some guys with early Mustangs that use those.
Cell's
Apr 7, 2014 09:28 PM
IcutMetl
Nov 8, 2010 09:12 PM
MasterBlaster
Jan 12, 2009 10:22 PM
sloppyjoe
20
Feb 20, 2008 12:22 PM
FEmtnmax
Nov 20, 2006 09:53 PM
