engine oil in coolant system
Old Nov 18, 2006 | 09:16 PM
FEmtnmax's Avatar
FEmtnmax
I had a problem with oil in the coolant. Head gasket leaks appear to have been the problem. Now I'm trying to get all the oil out of the coolant system. I flushed the coolant system several times with cleaners, but I'm still seeing oil seeping thru the heater hoses.
There is no water getting into the oil, so I'm thinking I have oil residue in the coolant system.
I took the short block apart and had hollow pushrods fitted to the oil passages in the block that feed the cylinder heads. I'm wondering if the oil passages in one of the cylinder heads is leaking, maybe take the heads apart and have their cooling systems pressure checked.
My next step should be to remove the radiator and heater core, have them hot tanked and flushed, flush the block, then install all new hoses.
What are your suggestions for eliminating the oil residue from the coolant system??
Old Nov 18, 2006 | 09:51 PM
passengass's Avatar
passengass
DAWN dish soap
Old Nov 18, 2006 | 10:19 PM
Bear 45/70's Avatar
Bear 45/70
Agreed, Dawn is the stuff to use and you can either run the motor of use a flushing kit and hot water.
Old Nov 20, 2006 | 04:54 AM
4starcstms's Avatar
4starcstms
So just fill with water and dawn run till hot then drain? Repeat sevral times or.........wut?
Old Nov 20, 2006 | 01:20 PM
Bear 45/70's Avatar
Bear 45/70
That will work. When the stuff you drain doesn't have oil in it you can stop. Flush a couple of times with straight water and when the soap is gone, fill with water and antifreeze.
Old Nov 20, 2006 | 09:53 PM
FEmtnmax's Avatar
FEmtnmax
Good deal!! Thanks
BryanStein
Sep 23, 2015 10:54 PM
GuitarJesus
Apr 16, 2014 11:56 PM
ALL AMERICAN BOY
Dec 21, 2011 03:26 PM
dawiz
Apr 9, 2011 05:40 PM
blupastu408w
Escape & Escape Hybrid
17
Mar 26, 2011 04:29 PM
