tranny swap?
Old Sep 29, 2003 | 01:57 AM
zdog's Avatar
zdog
Cool tranny swap?
I am getting ready to swap out transmissions in my 80 f-150 shortbed and am wondering if there are any complications I'm not thinking of... I'm switching out the original C6 with a five speed out of a 97 f250. I already have the pedels and column taken care of but still am not sure about transmission mounts and overall transmission length difference. Any tips or suggestions would be much appreciated.
zdog
[IMG][/IMG]
Old Sep 29, 2003 | 06:03 PM
f100guy's Avatar
f100guy
the tailshaft on a c6 might be a prob. not sure how many splines are on the manual but they might not line up. i don't know if the blocks are the same also
Old Sep 29, 2003 | 07:18 PM
zdog's Avatar
zdog
The engines are both 351w so that shouldn't be a problem, and I am switching transfer cases as well.. the only problem I should have there is switching the yoke on the transfer case since it is out of a 3/4 ton. If the tailshafts are the same i wouldn't mind staying with the original 208 transfer case.
Old Sep 29, 2003 | 09:19 PM
Txquadhunter24's Avatar
Txquadhunter24
zdog, They got a post goin on Down in the Tranny fourm about doin a ZF 5 Speed swap like you have. might try lookin it over.
Old Sep 30, 2003 | 11:26 AM
Derek83's Avatar
Derek83
yeah you may run into a problem with the c-6 length at the tail stock, The c-6 is big and the 5 speed will be smaller, i've done a c-6 to aod switch and it wasn't to bad. You may have a few problems but nothing serious, maybe check the tranny forum
zdog
15
Jun 11, 2020 10:09 PM
zdog
22
Jan 31, 2015 08:04 AM
zdog
Feb 17, 2006 04:09 PM
zdog
Oct 13, 2003 03:31 AM
zdog
Jun 18, 2003 11:08 AM
