Mystery O-ring
Old Jan 21, 2019 | 06:32 PM
Nixoninc's Avatar
Nixoninc
Mystery O-ring
So there I was, minding my own business, changing out the stand pipes and dummy plugs on the truck in my signature. I had to pull the oil rail on the driver side to get at & remove the lower part of the old standpipe. As I put the oil rail back on, I noticed a mysterious o-ring laying in the valley between the HPOP cover and the oil cooler housing (the turbo and pedestal are out) that appeared out of thin air. In the attached picture, I've placed a dime next to the o-ring for scale. For the life of me, I can't figure out where the hell this tiny o-ring came from. It's looks like it's tan in color.
Any one recognize it and know where it is supposed to be? Many Thanks ~ Kurt
Old Jan 21, 2019 | 08:34 PM
SmackDaddy's Avatar
SmackDaddy
Check your stand pipes
Old Jan 21, 2019 | 08:56 PM
willydmax's Avatar
willydmax
Is it like the tan o'ring from the blue spring fuel pressure upgrade kit? I can't think of a tan o-ring coming from anything at the turbo area.
Old Jan 21, 2019 | 10:03 PM
Thor'sHammer's Avatar
Thor'sHammer
ICP sensor seal?
Old Jan 21, 2019 | 10:19 PM
87crewdually's Avatar
87crewdually
That pic doesn't look real brown but this ^^ makes the most sense if it is.
Old Jan 22, 2019 | 04:29 AM
Yahiko's Avatar
Yahiko
Is it true round or has a flat back side sort of like a " D " ?
Old Jan 22, 2019 | 07:44 AM
SmackDaddy's Avatar
SmackDaddy
Like an injector top seal?
Old Jan 22, 2019 | 01:57 PM
Yahiko's Avatar
Yahiko
No I was still thinking D-ring. (Stand pipe/Dummy plug)
An air test would also be a quick way to test.
Old Jan 22, 2019 | 02:01 PM
SmackDaddy's Avatar
SmackDaddy
Yessir that’s what I was referring to in the first reply. I hate when I have mystery parts especially after the job is “done”.
Old Jan 22, 2019 | 03:19 PM
Yahiko's Avatar
Yahiko
I don't think most know just how flat the D-rings are on the inside. They are also very stiff and if
you ever remove one and put a new on on you need to give it an hour to shrink back after being
stretched to work it in place. Same thing goes with the little Teflon seals in the power steering system.
They need time to relax back to the un-stretched sizing.
In looking at a dime I don't think it's a D-ring or an injector top seal. So that brings us back to the
Blue Spring Kit or an O-ring from the EOT Sensor or Oil Pressure Switch.
Old Jan 22, 2019 | 07:31 PM
Nixoninc's Avatar
Nixoninc
I believe it is an o-ring from the fuel filter housing now that I have read all the comments and seen a picture of the blue spring kit.. I had to remove the intake manifold so I could remove the passenger side bolts on the HPOP cover, so it could've fell out when I disconnected the fuel lines from the fuel filter housing. I'll go check it out as soon as I complete a couple of "honey-do's" for the wife.
Old Jan 27, 2019 | 10:08 AM
Nixoninc's Avatar
Nixoninc
Epilogue - That o-ring was from the fuel line that goes to the driver side head, where it connects to the secondary fuel filter housing.
Thank you for all your help!
BRay09
Jan 8, 2019 08:05 AM
cbond007
Feb 22, 2015 06:41 PM
gwg42
Mar 9, 2013 12:26 PM
Fordownsall
Apr 11, 2011 08:44 AM
