7.3l electrical problems
Old Jan 19, 2019 | 01:12 PM
rnhent12's Avatar
rnhent12
I have a 1999 f-350 dually 7.3l diesel sometimes when it is parked the horn randomly starts blowing radio comes on battery runs down I don't know where to start troubleshooting any suggestions Thanks
Old Jan 19, 2019 | 03:31 PM
DieselDenny's Avatar
DieselDenny
Eyeball the moisture on the drivers side floor and higher.
Sounds like the welt in your shield is feeding conductive moisture to your electrical privates.
Denny
Old Jan 21, 2019 | 07:28 AM
axmrdr's Avatar
axmrdr
Do you have some type of alarm on it? Could be the place to start.
Old Jan 21, 2019 | 08:45 AM
rnhent12's Avatar
rnhent12
I have a lund racerback and lighted visor that I am going to remove and sell as I am putting a slide in camper on the truck I see where it is leaking around the windshield that is probably the problem I will have to reseal the windshield can I do this myself?
Old Jan 21, 2019 | 09:13 AM
Walleye Hunter's Avatar
Walleye Hunter
That's a question only you can answer but I can tell you that I wouldn't try it.
Old Jan 21, 2019 | 09:44 AM
rnhent12's Avatar
rnhent12
I found a glass place that will come out and install a new carlite windshield for $199.00 plus tax I think that is the best way to go Thanks for the advise
Old Jan 21, 2019 | 09:48 AM
DieselDenny
Outstanding idea.
The pros need to do this job. I've seen many try and fail as a DIY project.
Denny
Old Jan 21, 2019 | 11:29 AM
Walleye Hunter
When they do it be there and inspect the situation, it is possible that you have some rust/corrosion around the windshield that should be addressed before reassembly.
Old Jan 21, 2019 | 12:04 PM
rnhent12's Avatar
rnhent12
I will definitely do that they are coming to my house and I have everything to fix it if needed thanks
Old Jan 28, 2019 | 09:10 PM
kbeefy's Avatar
kbeefy
I would probably suspect a failing body control module.
autoxtech
Dec 2, 2011 07:53 PM
rackhound
Arizona Chapter
16
Jul 25, 2010 01:05 PM
chuy
Jul 13, 2006 07:46 PM
jay1971
Dec 1, 2003 08:09 AM
