Update 59 build
Old Jan 19, 2019 | 08:30 AM
Budro574's Avatar
Budro574
Update 59 build
Morning fellas,
things are going great with the build. Very happy with everything thus far. Knowledge on the forum has been invaluable and saved me $1000s. Sniper carb, fuel pump, rear sealed up, fuse block installed, wiring harness for accessories, and upholstering the bench seat at the moment. Given the power demands, the truck needs something stronger than the old generator, so I’ll be doing the gen to alt swap. I was going to use spacers and the old bracket as others have already done, but I’m trying to think a bit ahead. JEGS has an alt-a/c bracket for $150, but says I’ll need to replace the crank pulley as well. Another $150.... the trucks going to get a/c this spring. The only hiccup is the performance gets squared away next winter. After I upgrade the suspension, mustang 2 front end most likely. Blowers are 2 expensive for minor HP gains $3000+ from Rex hp. I want 500 out of the truck. Friends got a Nova, so it’s mostly about being faster than him. This’ll happen by stroking to a 331, lower compression heads, cam, then adding a turbo. This is an expensive option compared to buying a used 351 rebuild/stroke kit cam and heads for similar HP. Any opinions regarding the set up? The y block is cool and different, but is this a practical and reliable set up for the HP I want out of it?
Old Jan 19, 2019 | 08:31 AM
Budro574's Avatar
Budro574
Tried to post some pics but wouldn’t let me attach
Old Jan 23, 2019 | 09:20 AM
Byrd.Dog's Avatar
Byrd.Dog
If you're going with a mustang or crown vic front suspension, might as well swap to a 5.0 or 5.8. Just a lot more options for making the power you're talking about, I could see building the Y-block if you were doing a "Period-Correct" hot rod, and there are some performance options for it, but I don't think it will quite make it to your power level goal. If you've got the $$$ check out some of the Coyote 5.0 swaps some of the guys here have been doing - wicked cool! https://www.ford-trucks.com/forums/1...n-project.html
earl92
Apr 23, 2015 10:53 AM
jsparrow
Feb 26, 2010 11:26 PM
jackofalltrades
Bronco II
20
Sep 12, 2008 05:49 AM
Himura77
1978 - 1996 Big Bronco
Mar 15, 2005 11:48 AM
luvinfords
Oct 10, 2004 03:39 PM
