tank selector valve
Old Jan 17, 2019 | 09:39 AM
ernsppw's Avatar
ernsppw
tank selector valve
Only shows running off the rear tank. I replaced the switch a few weeks back and has been working fine. Filled up yesterday and the fuel gauge doesn't show the change when I change tanks. I'm guessing the selector valve back by the tanks? Any tricks or advice on swapping these?
Old Jan 17, 2019 | 09:49 AM
farmert's Avatar
farmert
You might want to check fuse #6 in the in cab fuse panel, as it protects the selector valve circuit. If that fuse is good, it is pretty straight forward to replace the valve, although the plastic clips that hold the fuel lines on can be a little tricky to get out sometimes.
Froger1
Jul 19, 2018 11:16 AM
Mi-Cyn
Oct 7, 2015 10:11 AM
f100guy
13
Oct 13, 2011 11:34 AM
Swineren
25
Feb 27, 2010 07:44 PM
Riata_Ag
Dec 5, 2008 07:34 PM
